I'm basically wondering if I can stick with Home Premium, or if I'm going to need the XP mode available in the Ultimate Edition. I just need to know if people have found the following A/V software to work okay in W7:
VirtualDub (with x264vfw)
AVStoDVD
Avanti
WinFF
ffdshow
ffmpeg
Audacity
Imgburn
Input much appreciated. Thanks!
	I have those and other legacy software running perfectly on Win 7, 64 bit.
	You may as well bite the bullet and plunge in; XPs death countdown has started by M/Soft. If you are going to do it, do it right and get Ultimate. You can configure permissions, registry and system far more.
 http://www.computerworld.com/s/article/9226023/Microsoft_starts_XP_retirement_countdow...?taxonomyId=89
	Those programs will run, but you can get more problems with win7. They moved away from backward compatibility to a large extent, which they're going to really do with windows 8. This has been a big problem for freeware coders . Winff, for example, still isn't win7 compatible. It's written in an open source Pascal that isn't.
 Specifically, Microsoft tech support recommends that you not use any 3rd party codec / splitter packs that modify your registry to point the whole system away from directx et al. Ffdshow is one of those.
 I won't use any of those codecs/splitters that bugger up the registry, and programs that don't need them work better. PLus I don't worry about conflicts. Avstodvd was the last program I had that used them and I yanked it. If I want to make a DVD, which I haven't done for a while, I'll probably use avidemux or something similal as a front end for dvdstyler.
 I don't mean to dissuade you from win7. Microsoft may still release updates for it but technically they don't support it anymore. Windows 7 isn't the resource hog that Vista is either. I know a couple of tech support people who've installed win7 on 6-7 year old laptops and it runs just fine on them.
  Upgrade laptop to windows 7?By mr-scarface in forum ComputerReplies: 11Last Post: 29th Aug 2010, 00:21
  Video Stutters after windows 7 upgradeBy Habby in forum ComputerReplies: 5Last Post: 10th Mar 2010, 21:56
  Windows 7 BSOD after upgrade from VistaBy Poppa_Meth in forum ComputerReplies: 11Last Post: 30th Dec 2009, 06:51
  Windows 7 Upgrade Makes Some PCs UnusableBy deadrats in forum ComputerReplies: 88Last Post: 5th Dec 2009, 05:14
  Free upgrade from Vista to Windows 7 - Dream on!!!!By videobread in forum Newbie / General discussionsReplies: 6Last Post: 26th Jun 2009, 23:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
