I am receiving these two errors when I extract MPG from VOBs
Error 1
Version: VOB2MPG PRO
Build: 3.2.2000
Type: System.IO.IOException
Source: mscorlib
Message: Data error (cyclic redundancy check).
InnerException:
StackTrace: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.ReadCore(Byte[] buffer, Int32 offset, Int32 count)
at System.IO.FileStream.Read(Byte[] array, Int32 offset, Int32 count)
at System.IO.BufferedStream.Read(Byte[] array, Int32 offset, Int32 count)
at VOB2MPG_PRO.VOBConverter.xaa5715e3ca1bcc71.x06b0e2 5aa6ad68a9(Byte[] x9d5750eb2d6373bc, Int32 x374ea4fe62468d0f, Int32 x10f4d88af727adbc)
at VOB2MPG_PRO.VOBConverter.xa4923bf9ed944f6a.x5efa88 7f424cce7c(x0010d7171147daf4 xb867a42da3ae686d)
at VOB2MPG_PRO.VOBConverter.xa4923bf9ed944f6a.xf09832 3036d9ec26(String x0fb01370f21139f0)
at VOB2MPG_PRO.VOBConverter.xa4923bf9ed944f6a.xa0a575 fb460f53aa(String x37a96021dbbe3532, String x0fb01370f21139f0, String xd8195b3904c80823, Boolean xf140bfb3a6ec89d8)
Error 2
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Threading.ThreadStateException: Current thread must be set to single thread apartment (STA) mode before OLE calls can be made. Ensure that your Main function has STAThreadAttribute marked on it.
at System.Windows.Forms.Clipboard.SetDataObject(Objec t data, Boolean copy, Int32 retryTimes, Int32 retryDelay)
at System.Windows.Forms.Clipboard.SetDataObject(Objec t data, Boolean copy)
at VOB2MPG_PRO.x529c233d07ffb0d5.x78aff39af5f148a1(Ob ject xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at DevComponents.DotNetBar.ButtonX.OnClick(EventArgs e)
at DevComponents.DotNetBar.ButtonX.OnMouseUp(MouseEve ntArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at DevComponents.DotNetBar.PopupItemControl.WndProc(M essage& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5448 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
VOB2MPG
Assembly Version: 3.2.2000.0
Win32 Version: 3.2.2000
CodeBase: file:///C:/Program%20Files%20(x86)/VOB2MPG%20PRO/VOB2MPG.exe
DevComponents.DotNetBar2
Assembly Version: 7.7.0.2
Win32 Version: 7.7.0.2
CodeBase: file:///C:/Program%20Files%20(x86)/VOB2MPG%20PRO/DevComponents.DotNetBar2.DLL
Win32 Version: 2.0.50727.5446 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.5453 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 2.0.50727.5458 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
DirectShowLib-2005
Win32 Version: 2.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/VOB2MPG%20PRO/DirectShowLib-2005.DLL
MessageBoxHook
Assembly Version: 0.0.0.0
Win32 Version:
CodeBase: file:///C:/Program%20Files%20(x86)/VOB2MPG%20PRO/MessageBoxHook.DLL
msvcm80
Assembly Version: 8.0.50727.6195
Win32 Version: 8.00.50727.6195
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727. 6195_none_d09154e044272b9a/msvcm80.dll
Accessibility
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
AxInterop.CodeLock
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/VOB2MPG%20PRO/AxInterop.CodeLock.DLL
System.Xml
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Interop.CodeLock
CodeBase: file:///C:/Program%20Files%20(x86)/VOB2MPG%20PRO/Interop.CodeLock.DLL
System.Design
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
System.Management
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
System.Deployment
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Could you please tell me how to resolve these error messages so that I can extract my mpgs from my vobs.
Yes I am extracting from a DVD. I am also using DVDFab Passkey.
I can rip them using DVD Decrypter but I still get the error when I attempt to extract the mpg from the vobs.
DVDDecrypter
Latest version:
3.5.4.0 (March 21, 2005)
No longer developed, use DVDFab Decrypter or AnyDVD if you get any ripping problems.
VOB2MPG-PRO: Problem extracting VOBs from Verbatim DVD+R Dual Layer (8.5GB)
By rickyp513 in forum DVD RippingReplies: 1Last Post: 25th Aug 2010, 17:47 -
extracting vobs by episodes
By octeuron in forum Newbie / General discussionsReplies: 7Last Post: 5th Apr 2010, 01:54 -
Extracting VOBs To M2V gives me alot of problems.
By Discov3r3d in forum DVD RippingReplies: 5Last Post: 18th Aug 2009, 16:41 -
avidemux subtitles, fatal errors
By stevencg in forum Video ConversionReplies: 1Last Post: 15th Feb 2009, 04:13 -
extracting vobs from mdf files
By uglijimus in forum Newbie / General discussionsReplies: 7Last Post: 15th Jun 2007, 14:15
