I have a Canon XA10 and was going to use an older SD cam with it in a multicam shoot, but think it will be better to use another HD camera, plus my SD cam uses tape, so it would be harder to match up the files against the tape. I'll use the audio from the XA10 and just need a cheaper but still decent consumer cam for the other angle that also records in AVCHD, with the same framerate available to make everything go smoothly in post.. Any suggestions?
price range? maybe borrow one from a friend if this is a one time thing.
Definitely not a one time thing. I went to the Canon website and used the compare feature and think I know which one I'm going to go with, the VIXIA HF M500 which is under $600 and I believe uses the same image sensor as my XA10.
should work fine with what you have and the price is pretty good.
Am I missing something, or is the only major difference between the M400 and newer M500 that they actually took away one memory card slot? What, if anything makes the 500 model better than the older 400 model? See compare at Canon:
http://www.usa.canon.com/cusa/consumer/products/camcorders/consumer_camcorders?pageKey...01e0248024aa4e
NE1 use a Canon XA10? Need help with setting exposure w/ 18% grey card
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 19th Jul 2012, 08:46 -
Capture files over HDMI on Canon XA10
By shane123 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 25th Apr 2012, 02:47 -
Canon XA10 field of view question
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 7th Feb 2012, 15:09 -
Suggestions for decent tripod for Canon XA10?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 7th Feb 2012, 15:02 -
Using SLR ( Canon 5D mk2 ) to Shoot Movies ?
By stacks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 23rd Feb 2010, 03:49
