Hi All,
I couldn't get these 2 codec to install on my Windows 7 64bits system. Is it possible to install 32 bits codec on a 64 bits OS ?
I am trying to get my VirtualDub 32bits to work so that I can frameserve to an encoder.
Thanks in advance.
Yes, you can install 32 bit codecs on 64 bit Windows. The 32 bit and 64 bit A/V systems are completely separate, like having two different computers. You may need to use a special install procedure:
https://forum.videohelp.com/topic332208.html#1723154 -
Hi jagabo,
Going through this manual installation, am I still able to unintall them if I want to ? -
Yup you can. Just go into your control panel and uninstall it just like you would with a regular program
MKV AAC GUI Converter with Nero AAC Codec
By prijatelj.v in forum AudioReplies: 4Last Post: 26th Mar 2012, 09:41 -
Trouble installing AC3 ACM codec on 64 bit OS
By Teemo in forum AudioReplies: 0Last Post: 30th May 2011, 16:42 -
how to encode aac 5.1 to ac3 on the fly in 64-bit windows 7
By MR 3 in forum AudioReplies: 3Last Post: 4th Apr 2010, 18:47 -
Why is virtualdub 32bit much slower on windows 7 X64 than winxp 32bit?
By TigerSoul in forum EditingReplies: 4Last Post: 26th Mar 2010, 16:13 -
Windows Vista - 32bit or 64bit?
By HatchetMan in forum ComputerReplies: 29Last Post: 12th Jan 2008, 01:24
