Maybe I'm just not able to find the right setting in the above titled software even though I've used many versions over the years. The program always assumes my inputted DVD is 30 fps not 29.97 so after I get the srt, I have to run it thru some other software program and tell it to convert 30fps to 29.97.
Is there a setting in DVDSubEdit to tell it that the input is not 30 fps?
Tony
In File->Preferences there's a box you can check to force it to use drop-frame time code. Try that.
Thanks...... Seems to have fixed the problem. Even after reading the DVDSubEdit
manual I still couldn't find where they mentioned it.
Tony -
You're welcome.
It was only implemented in the most recent version, well after the manual was written (and never updated, apparently).
Remove duplicate text from SRTs
By cal_tony in forum SubtitleReplies: 8Last Post: 4th Jun 2014, 10:31 -
Batch rip SRTs from VOBs?
By Luth C in forum Newbie / General discussionsReplies: 10Last Post: 28th Apr 2012, 20:47 -
Notepad to spellcheck SRTs with underscore facility
By cal_tony in forum SubtitleReplies: 8Last Post: 2nd Nov 2011, 22:43 -
Error in DVDSubedit when re-timing subtitles
By kpic in forum SubtitleReplies: 2Last Post: 22nd Feb 2010, 04:08 -
DVDSubEdit time error in .srt
By Arlo in forum SubtitleReplies: 5Last Post: 2nd Feb 2009, 03:18
