Hi everybody
I managed to create a separate batchfile for each different audio-routing scenario that I can run at my conveniënt time, simultaneously or not. Googling around I also created a "kill all" batch for ending all audiorepeaters. The command-line of it looks like this:
taskkill /im "audiorepeater.exe"
This batch ends all running audiorepeaters of all started batches. This can be usefull, yes.
But I realized I also want separate batchfiles for ending a separate scenario that I started in the case that multiple routings are running. In the system-tray the repeaters are all the same and can be quite numerous; one batchfile can run a lot of repeaters for one routing scenario. Multiple batchfiles will add more and more. In taskmanager all audiorepeaters.exe files are the same too.
Does anyone know how to create a batchfile that ends only those repeaters that one specific scenario-batch started running? Up front, I take it I have to start creating the separate start-batches in a different way.
Thanks in advance
Ennio
Results 1 to 1 of 1
MeGui: error in encoding: "x264.exe:unrecognized option --progress"
By Julllie in forum Video ConversionReplies: 4Last Post: 30th Apr 2011, 05:21 -
DVD Flick error message "ffmpeg.exe has stopped working"
By stewiegriffin711 in forum Authoring (DVD)Replies: 4Last Post: 17th Aug 2008, 07:20 -
NAME="mplayerc.exe" FILTER="GRABMI_FILTER_PRIVACY"
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 7th Aug 2008, 15:40 -
A question about suspicious "Rebuilder.child.exe" file in DVD Reb
By Talayero in forum DVD RippingReplies: 0Last Post: 8th Jun 2008, 10:17 -
question about how to remove this software, "wmfdist95.exe" WMA
By jimdagys in forum ComputerReplies: 2Last Post: 15th May 2007, 04:07
