  1. Well, basically I had problems to make a Blu-ray 3D movie to show .sup subtitles, so I followed these steps I found on this forum:
    Step 1:
    Use 3D Subtitler
    Create 3d subtitle *.sup file
    Duration ~ 5 minutes (depends cpu)
    Step 2:
    USE Tsmuxer
    Transform movie *.mkv to *.ts
    Duration ~ 15 minutes (depends cpu)
    Step 3:
    USE RipBot264
    Transform movie *.ts to *.mkv again
    Now in option use "Permanent subtitle" and use *.sup file from first step.
    CQ = 18 (Best quality)
    Duration ~ 4 hours (depends cpu)
    I followed these steps, and the one that fails is number 3. It starts ripping, goes on and then finishes right away. Here's the log:
    C:\>"C:\Users\Ignacio\Desktop\Programas para películas\RipBot264v1.17.0\tools\avs2yuv\avs2yuv.exe" "C:\Temp\RipBot264temp\job1\job1.avs" -o -   | "C:\Users\Ignacio\Desktop\Programas para películas\RipBot264v1.17.0\tools\x264\x264_x64.exe" --crf 18 --stats "C:\Temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --force-cfr  --min-keyint 24 --keyint 240 --frames 187650 --sar 1:1 --level 4.0 --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --b-pyramid none  --stdin y4m --output "C:\Temp\RipBot264temp\video.264" -
    The system cannot find the path specified.
    C:\>"C:\Users\Ignacio\Desktop\Programas para películas\RipBot264v1.17.0\tools\mkvtoolnix\mkvmerge.exe" -o "F:\Ignacio\Harry Potter and the Deathly Hollows Part 2 3D SBS(2).mkv" --compression 0:none --title "Harry Potter and the Deathly Hollows Part 2 3D SBS(2)" --default-duration 0:24000/1001fps  "C:\Temp\RipBot264temp\video.264"
    Elapsed Time: 00h:00m:00s
    Please guide me what to do to fix this.
    EDIT:
    Also, when setting permanent subtitles, clicking on preview tells me it can't find a .sub file, yet I want to use a .sup one.
  2. make sure that java x86 is correctly installed
  3. Nope, same result.
    I'm attaching the new log as it may be throwing something different this time.
    C:\>"C:\Users\Ignacio\Desktop\Programas para películas\RipBot264v1.17.0\tools\mkvtoolnix\mkvmerge.exe" -o "C:\Users\Ignacio\Desktop\Harry Potter and the Deathly Hollows Part 2 3D SBS.mkv" --compression 0:none --title "Harry Potter and the Deathly Hollows Part 2 3D SBS" --default-duration 0:24000/1001fps  "C:\Temp\RipBot264temp\video.264"
    I uninstalled, then reinstalled it.
