Ok so im new here and i was just reading the audio sync avi thread and i wasnt really sure what to make of it... so let me explain what is going on... basically i have a .VOD video file directly off a sony camera and the file will play ok... but to edit it i need it in a different format so i have been trying to convert it to avi or any format that will work in premiere but the issue is this: the timeline on the .vod says the clip is 9:46 m/s long however the clip is 26 mins long really... and even though it says its 9 mins long it will play the whole thing but at 12:59 m/s it stops running the time for abit and then restarts the timer at 0:00 after awhile and then plays out till 9:46. Now it is playing the whole clip but the timeline is just messed up... but when i try to convert it it either ends up with 9:46 sec or 13 min or it plays all the way through but after the 12:59 the audio is about 4-5 sec too early for the rest of the clip.... i have been at this for two days and i need this footage for a project.... i just dont know what else i can do...
yes i meant to say .vob from the start.... i really appreceate the help cuz i am so lost on what to do to fix this... the text is
General
Complete name : C:\Users\Haley\By way of moonlight\VTS_01_1.VOB
Format : MPEG-PS
File size : 1 024 MiB
Duration : 9mn 46s
Overall bit rate : 14.6 Mbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Duration : 9mn 46s
Bit rate mode : Variable
Bit rate : 14.1 Mbps
Maximum bit rate : 9 100 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 1.360
Stream size : 986 MiB (96%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Muxing mode : DVD-Video
Duration : 9mn 46s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : -66ms
Stream size : 17.9 MiB (2%)
Text
ID : 189 (0xBD)-32 (0x20)
Format : RLE
Format/Info : Run-length encoding
Duration : 9mn 46s
Menu -
Perhaps the clip is damaged? Mediainfo reports it to be 9min 46sec as well
There is probably a glitch after that point, which causes the sync issues you are observing
Anyways, the way you import it into premiere is use vob2mpg to re-wrap into mpeg2 stream, and it will import directly
This won't fix your glitch. If you have videoredo you can try the quickstream fix to repair it . The other way might be to cut around that desync point -
i have gotten other clips to work fine and i was converting them with AVS video converter but this one is just shot to shit i guess >.<
.avi to VIDEO_TS audio issues?
By floggens in forum ffmpegX general discussionReplies: 2Last Post: 5th Jun 2011, 13:52 -
WWE's VOD service is having video quality issues and nobody knows why
By Bix in forum Newbie / General discussionsReplies: 2Last Post: 4th Jun 2010, 14:19 -
Audio Sync Issues From AVI
By tyders in forum Newbie / General discussionsReplies: 5Last Post: 14th Apr 2009, 10:36 -
VERIZON Fios VOD Compatibilty issues
By Balefor in forum DVD & Blu-ray RecordersReplies: 2Last Post: 28th Mar 2008, 19:05 -
Audio Issues with .AVI files
By itsmevic in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2007, 18:15
... im using premiere cs5.5.... but i havent even got it to where it works in there yet.... i cant get the files to be right outside of premiere...
