I've located a video background that would work in my project. Problem is it's standard def (NTSC format=720 X 486, 29.97 fps)
http://www.uniquetracks.com/alpha-channel-film-strip-texture.html
My experience has been that converting standard def format to HD doesn't yield very successful results.
(I've used Compressor for this previously). I not so concerned with the crop/stretch that would occur in the new aspect ratio, it's more the visual quality.
This video is cheap enough to purchase, I just wonder if attempts to convert it will yield usable results. Has anyone had any luck converting their standard def stock video to HD format?
Many thanks.
PJ
	You don't want that. The holes aren't spaced evenly.
 I think there are free HD ones of the same style.
 You could easily make your own animated HD filmstrip.
 In fact, that filmstrip comes free with some editors.
 ...and welcome aboardLast edited by zoobie; 11th Apr 2012 at 13:13.
	thanks, I'll look for that. This particular animation had a little more going on in the alpha channel than a straight filmstrip animation but you're right, it's probably easier to find a HD one and go from there.
 PJ
	Also if it is to be purchased there might be some drm in it and you wouldn't be able to convert it anyway - not without doing a screencapture of it.
 Also if this were 4:3 I wouldn't stretch it to 16:9. I'd look for a 16:9 to begin with. I've got to believe 16:9 sd material would be better than 4:3 sd stretched to 16:9 hd.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
  stock video footageBy Brian G in forum Newbie / General discussionsReplies: 3Last Post: 23rd Apr 2009, 18:41
  Free stock footage clips for video editingBy joelholland in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 27th Jun 2008, 09:54
  Stock video footageBy gmc9960 in forum EditingReplies: 4Last Post: 9th Feb 2008, 15:27
  Visual FX and Stock Footage for Video EditorsBy Motiondrops in forum EditingReplies: 0Last Post: 14th Jan 2008, 16:39
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
