Hello
I have a .mts file 1920 *1080 that has been up converted to 59.94fps. Each frames are doubled. In order to reduce the size before uploading, I would like to drop half of the frames without reencoding. Is it possible with some tools (and maybe the help of avisynth)?
It's not possible unless it uses an all intra-frame format. All high compression codecs use inter-frame encoding. Most compressed frames only contain information about the changes from frame to frame. If you drop that information for one frame all the frames after it will be corrupt, until the next keyframe.
For example, with a five frame sequence:
frame 1) A
frame 2) previous frame + B = A+B
frame 3) previous frame + C = A+B+C
frame 4) previous frame + D = A+B+C+D
frame 5) previous frame + E = A+B+C+D+E
If you drop frames 2 and 4:
frame 1) A
frame 3) previous frame + C = A+C
frame 5) previous frame + E = A+C+E
As you can see, if you drop frames the final product is wrong.Last edited by jagabo; 11th Apr 2012 at 08:08.
ah yes.. sure. I didn't thought about this problem. When I demux an select a part of the video.. I should then only be able to cut after a group of pictures and not to a precise frame, right?
Correct, unless you re-encode (either the affected GOP only, or the whole thing)...
Scott -
Any section you keep must start with a keyframe. They can end anywhere (if you end on a B frame the last few frames may be corrupt). Some editors only allow ending in keyframes too.
Why does your system drop frames?
By txpharoah in forum Capturing and VCRReplies: 118Last Post: 12th Aug 2023, 15:13 -
why does Flash video drop so many frames ?
By davexnet in forum Video Streaming DownloadingReplies: 19Last Post: 1st Oct 2013, 07:04 -
convert fields into 50fps vertical half frames & back
By l.pandit in forum Video ConversionReplies: 3Last Post: 7th Feb 2010, 06:21 -
Mini-DV camera playback misses half the frames
By kimco52 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 13th Sep 2008, 21:22 -
Does current ADStech Pyro (firewire) w/Premiere still drop lots of frames?
By miamicanes in forum Capturing and VCRReplies: 9Last Post: 19th Sep 2007, 23:41
