Hi!
i'm new here.
I just got a 5 minutes DVD Video and i need some help with converting it to AVI.
i tried a few things, like AutoGK (get stuck everytime), and demuxing the V/A streams so i can convert it with VirtualDub (can't handle MPEG) but without any luck.
i also tried to look at the Tools section for useful tool, but i got lost there and i hope you guys can help me here.
what tool should i use?
i prefer it would be a freeware.
thanks in advance!
Hi manono, thanks for the help.
where can i extract a log?
i don't think it even gets to the log part. i choose my VOB file, click "Add Job" and then "Start", the Start button grey out, but other than that nothing happens. -
After hitting 'Add Job' the 'Start' button becomes available, which is what you said. Then you hit it and nothing happened and it became greyed out?
In the folder you've chosen to save the video should be the *video_name*_agc.log, which can be opened in Notepad. If it doesn't give you any useful information about why it stopped, the usual procedure for fixing inexplicable errors is to remove AutoGK and reinstall it again. You allowed it to install AviSynth, didn't you? And the other programs it needs to do its work? And initially you installed the full package and not just the update?Last edited by manono; 11th Apr 2012 at 16:32.
a better description of the source might help. is it really in dvd format? i.e. in a video_ts folder with ifos, bups, and vobs?
thank you both for your help.
manono
exactly.
now that i think about it, i might have skipped a few steps during the installation process. i'll try to reinstall.
aedipuss
this is how the video_ts folder looks like:
i also have it in m2v/mpa files (demuxed it with PgcDemux), and in MPG file (muxed it with ImagoMPG-Muxer).
Hd-DVD/VC1 conversion to AVI
By mpiper in forum Blu-ray RippingReplies: 10Last Post: 20th Mar 2011, 22:57 -
DVD to AVI Conversion ???
By babaki in forum Video ConversionReplies: 2Last Post: 23rd Aug 2010, 00:15 -
AVI to DVD conversion
By nick soapdish in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2008, 19:11 -
avi to dvd conversion
By whipleg in forum Video ConversionReplies: 3Last Post: 29th Jul 2007, 06:43 -
By mattman1968 in forum Video ConversionReplies: 3Last Post: 22nd May 2007, 10:06
