Using Virtual Dub, I'm trying to fix some bad/garbage frames on several large lossless (Largarith) master AVI files before I encode them to lossy formats.
Maybe I'm imagining things, but I seem to remember there's a way in VirtualDub to mask a frame where you blend, rather than duplicate, the replacement frame. And it's done without re-encoding, ie. in Direct Stream Copy mode.
In other words, you create a replacement frame by somehow blending the 2 good frames from before and after bad frame, rather than just using the "mask frame" feature which inserts a duplicate frame of the previous good frame.
Then you re-save the file in Direct Stream Copy mode
Is this possible?
Also try using motion prediction to replace the bad frames. I works well sometimes, not so well at others.
https://forum.videohelp.com/threads/344962-VHS-Cleanup-What-can-i-do?p=2152073&viewfull=1#post2152073
Fixing [D] Frames?
By Startropic1 in forum Video ConversionReplies: 1Last Post: 9th May 2010, 12:03 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 16:00 -
VirtualDub Filter Blending
By sambat in forum EditingReplies: 4Last Post: 6th Sep 2009, 15:07 -
Problem Fixing corrupted frames
By Blå_Mocka in forum Newbie / General discussionsReplies: 6Last Post: 13th Nov 2007, 09:44 -
Fixing bad tracking
By J C in forum RestorationReplies: 11Last Post: 7th Sep 2007, 08:11
