I have an mp4 video file that plays just fine, using Media Player Classic Home Cinema. The subtitles appear to be in regular Arial font, 18 pt, white text with black outline, just as I want them.
In ConvertX, the default settings are identical (ANSI_CHARSET). But when I convert the file to burn on DVD, the subtitles appear solid greenl and in a font similar to bold Impact, barely readable. I've never experienced anything like this before. Any idea what might be going on?
Djard
medfaith@yahoo.com -
Your subtitles are probably SRT, plain text with no font information. It's the subtitle renderer that decides what font (color, outline, and drop shadow) to use.
If I understand you correctly, the subtitle app that was used to create subtitles in the mp4 file is responsible for how the subs appear after I convert the file to DVD format (IFO, BUP, VOB).
Evidently what I'm told here is correct. But I'm wondering why the subs appear fine when I play the mp4 file with MPC, and why ConvertXtoDVD has settings for subtitle rendering if they have no influence on the conversion process. I just wish to lean more about video management.Djard
MPC uses one subtitle renderer, ConvertXtoDVD uses another. Each renderer decided for itself what font to use.
Djard
medfaith@yahoo.com
Burn subtitle and change font size
By Nazarenojr in forum ffmpegX general discussionReplies: 8Last Post: 14th Mar 2011, 04:25 -
How to change font size in a .sub subtitle file?
By nonexistent_entity in forum SubtitleReplies: 3Last Post: 15th Jun 2010, 14:36 -
How to change srt Subtitle style and font size in MEGUI ?
By DARIFBS in forum SubtitleReplies: 4Last Post: 12th May 2010, 14:19 -
Change Font Colour for .srt subtitle file!
By mufu in forum SubtitleReplies: 2Last Post: 5th Nov 2008, 14:45 -
VobSub change font
By Digiface in forum SubtitleReplies: 3Last Post: 3rd Jun 2007, 15:21
