I'm trying to make some death counter overlays for a project i'm working on for my youtube channel for a minecraft project. But i don't know how to render without having to have a black back ground there.
The death counters are the players minecraft characters walking on screen, then dieing with a number next to their avatar to show how many times they have died, like Haat Films do in their videos: http://www.youtube.com/watch?v=r6DJq...feature=relmfu in this one @15.37 to see what im on about. I have made one of these animations albeit worse ones for each of the the characters taking part in my series. IS there any way that i can render them out of after effects without the black background so i can use them in Sony Vegas? or is it impossible and i may aswell just render the whole videos out in After effects, although Vegas is better for sound and long pieces of editing?
Any help would be much appreciated
Yeah, rarely, if EVER, do video apps actually NOT have data filling all the pixels in a layer (native compositing apps are an exception here), so in a sense you HAVE to put something there.
Like AlanHK said, you pick a (normally unused) color and designate that color as your transparency. Then it's the job of the next app (the one that uses this video in the foreground with something else in the background) to understand this "transparency" color and do the math to overay it correctly.
Scott -
I think he's asking how to render it out of AE for import into Vegas. I'll assume that you made the overlay assets in AE ok (If not, come back)
You need render it with alpha channel, make sure it's set to RGBA mode , not RGB mode (the "A" is for alpha channel or transparency) in the render settings
Formats that are commonly used and compatible with Vegas are animation codec (quicktime MOV), uncompressed RGBA (either AVI or MOV), lossless compression e.g. Lagarith AVI (in RGBA mode) or PNG or TIFF sequences with alpha
Although you could, I wouldn't use AE to do the whole thing. Like you said earlier, Vegas is much better for editing and audio. Only do those assets that you need to in AE , then export them for Vegas -
True, pdr, and that's what I would recommend also, but even then with an Alpha channel added, it still has SOME kind of info in the main pixels (hopefully BLACK).
It may not have been stressed enough: you have to select & generate an alpha channel 1st and then upon export choose a file format that FULLY supports alpha channels.
Scott -
How to render a video without a background
By xX-Towrd01-Xx in forum User guidesReplies: 3Last Post: 10th Apr 2012, 09:53 -
Help! When I render a video in Adobe After effects, theres no sound!??!?!
By Devilsadvocate in forum EditingReplies: 4Last Post: 21st Mar 2012, 09:02 -
Best render for 4:3 video using Sony Vegas pro 10 for youtube
By fuzzblaster in forum Video ConversionReplies: 0Last Post: 9th Jan 2011, 13:18 -
PC does not render video camera HD .mov's well
By Whane The Whip in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 22:02 -
How To Render Video File Same As Source?
By GizzmanSL2 in forum EditingReplies: 2Last Post: 20th Oct 2009, 15:46
i rendered it with RGB alpha channel, then when i imported it into
