  1. Hello everyone.
    I dont know where to start or the info you need to help med, but i will do my best.
    1.I rip TV with my Terratec H5 its a Digital channel and its recorded in TS.
    2. Then I put the video in STAXRIP to cut the commercials away, and convert it to MP4 and audio i AAC and puts birate to 3000 Kbs its HD.
    3. Then when I am watching the converted file (its soccer) its like when the screen are movin fast when they clear the ball or there is a goalkick, it like the sceen is jumping..
    The point for me converting is because I use all my videos streaming with my XBOX 360 trough PS Mediaserver.
    Hope you know what the problem is.
    Sincerly JackDanielZ
    Post the video details from the ts. Use mediainfo, view->text copy. You could also upload a very short video ts sample.
  3. Here it is:
    General
    Complete name : C:\Users\Daniel\Desktop\04-05_17-55-03_TV3+HD_Fodbold Superligaen.ts
    Format : MPEG-TS
    File size : 7.78 GiB
    Duration : 2h 4mn
    Overall bit rate : 8 910 Kbps
    Video
    Menu ID : 7000 (0x1B58)
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Format settings, GOP : M=8, N=24
    Codec ID : 27
    Duration : 2h 4mn
    Bit rate : 8 082 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : MBAFF
    Bits/(Pixel*Frame) : 0.156
    Stream size : 7.05 GiB (91%)
    Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : 6
    Duration : 2h 4mn
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Delay relative to video : -976ms
    Stream size : 343 MiB (4%)
    Language : Danish
    I would try convert with something else. Try vidcoder or handbrake and see if it makes any difference. You can't cut with it though.
    But it could be because of interlacing. Most TS 1920x1080 sources are interlaced and if staxrip are doing any deinterlacing it could look strange in fast motions.
  5. I think the thing thats was is called Pull down.. I will try what you told me now.. Can it have something to do with framerate?
