DVD disk freezes during playback after being finalized
Hello. I have HDD DVD recorder Philips DVDR 3455 and recently is creating me big troubles with the disks created. from this reorder. DVD disk freezes duringplayback after being finalized. I tried all possible DVD disk brands like Sony,Maxell, Memorex, Fuji etc, but the same trouble. After finalizing the disk, Iam trying to play them back in different DVD players or PC, but the video freezes just in first 2-3 seconds. Any solution? Thanks
Results 1 to 11 of 11
The technical support of Philips told me to update the machine driver from website. I did it, but no solution yet...
If it were me I'd rip the DVD to my computer and re-author a new one WITHOUT the Philips menu....or with no menu....see if that helps.
Having grown up in the now almost deceased "DVD Recorder" world with a $600 Philips DVDR-985 DVD recorder bought way back in the day....even then there was software to fix problem-discs created by DVD recorders.
FixVTS was originally written with such discs in mind...and that was back when discs were....what...10x the price as they are today?
And Sony,Maxell, Memorex, Fuji etc etc discs are not good discs. The only discs worth buying these days are (most)Verbatim and Taiyo Yuden....though I doubt that will solve your problem.
Also make sure you turn OFF auto-chaptering on the recorder.
Your DVD recorder is a model released in 2006. After a few years of moderate to heavy use, the DVD burners in DVD recorders generally start to fail and no longer burn reliably. That is what is probably happening. The solution is to have the DVD recorder repaired, or get a new DVD recorder.
Yet oddly we have plenty of posts to the contrary about that. The good Verbatim and all TY discs work reliably for everybody. If you want to save money and roll the dice on other brands, that's your business. But you may be doing things like burning at low speeds that increase your chance of success and other users won't do that.
Think about it. Unless the DVD drives on all the other equipment you tried have simultaneously begun to fail, or all the DVDs you have burned recently have a similar manufacturing defect, something has to be wrong with the DVD recorder's burner. The burner appears to be the only constant in your tests.
Every component in a machine has a "mean time between failure", but it is only an average. Sometimes parts will fail long before they should and sometimes parts will work much longer than expected.
Recover not finalized disk
By dexter30 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 12th Apr 2009, 17:27 -
Reading non-finalized DVD's?
By Noiseworker in forum Authoring (DVD)Replies: 9Last Post: 7th Jan 2009, 18:37 -
What happens that a disk can't be finalized?
By Des in forum DVD & Blu-ray RecordersReplies: 8Last Post: 20th Oct 2008, 07:34 -
Jerky Playback (as if disk was scratched!) on a newly made DVD (From AVI)!
By xxjustinukxx in forum Authoring (DVD)Replies: 5Last Post: 10th Apr 2008, 08:23 -
DVD recordings HDD to DVD-R freezes during playback
By NiteLite in forum Newbie / General discussionsReplies: 4Last Post: 16th May 2007, 01:51
discs. Last months I made 50-60 DVDs without problems.
