I had old codecs which had worked well. Anyway, I did want update them, so I downloaded last K Lite Codec, and after the installation several codecs were missing.
With a lot of missing codecs, it's impossibile for me to use software like video converters.
So, I uninstalled K Lite Codec and install an old version of K Lite, and I solved the problem
Anyway, how can I do to update the codecs without losing some of them?
ffdshow dropped a lot of old encoders quite a while back,...
see: http://forum.doom9.org/showthread.php?p=1467129#post1467129 and http://forum.doom9.org/showthread.php?t=159425 for why,.. -
I read...
So, how can I solve this problem?
If I install K lite Codec and then single codecs (xvid and so on), I didn't solve anything. -
... except then you have to be careful about whether a new program install will install a newer version of ffdshow along with it ... also whether some of the hackers out there who write some of this stuff will support your older version ... when they say they need a "stable version" of ffdshow it usually means that's the only version their code works with.
Sorry to say this, but I won't use ffdshow or any similar silly non microsoft codecs/filters/splitters anymore. I don't have problems converting or playing either. -
VirtualDub Compression Codecs All missing?
By blazr in forum Newbie / General discussionsReplies: 0Last Post: 29th Feb 2012, 06:14 -
k-lite mega pack codecs 6.30 problems...
By sgbd in forum Software PlayingReplies: 10Last Post: 2nd Sep 2010, 05:46 -
missing audio codecs WMP11 ??
By DirtBikeMike in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2010, 11:30 -
Vista Codec Pack or K-Lite Codecs
By gonwk in forum Newbie / General discussionsReplies: 4Last Post: 13th Oct 2009, 20:07 -
How to reinstall the codecs? (K-lite, XVID, etc.)
By dzsoul in forum Newbie / General discussionsReplies: 3Last Post: 19th Mar 2009, 06:08
