Using Sony Vegas Pro 11, I have different sources of FPS in my project, some 60 FPS, some 23.97 FPS. I want to render it at 60 FPS but how will this affect the 23.97 FPS clips?
If you have 59.94 FPS timeline project settings and export settings, 23.976 sections will have duplicated 3-2 frames (AAABBCCCDD... etc..) to make up the 59.94 if you have resample disabled for the clip (right click the clip properties). This is the way it is normally done
Videos with different framerates need to be joined together
By vertigoelectric in forum Video ConversionReplies: 15Last Post: 18th Mar 2012, 04:21 -
Editing and rendering with multiple frame rates?
By vid83 in forum EditingReplies: 12Last Post: 2nd Mar 2011, 04:20 -
Audio from movies with non-standard framerates.
By Maikeru-sama in forum Authoring (DVD)Replies: 16Last Post: 30th May 2008, 18:21 -
Rendering multiple wmv files with Vegas
By smarshall in forum EditingReplies: 3Last Post: 3rd Apr 2008, 13:23 -
Framerates and converting to DVD
By exekutive in forum ffmpegX general discussionReplies: 6Last Post: 18th Jun 2007, 01:31
