Thanks for the reply, and looking into the lil bug.
I'll tell you why and when I use mks subs.
No, you won't come across them in general.
BUT, if you (de)mux them from mkv directly, they keep any linked attachments, such as fonts.
That makes it easier to automate an encode, I've found. Just muxing the .ass or .ssa sub
does not guarantee that the subs will display as they should. In fact, even extracting and
muxing fonts later on does not guarantee they will display in that font for some reason.
PS I'm referring specifically to anime encodes and their pretty fonts...
PPS mks can also encapsulate chapter data and multi-subs in one file, which is useful for passthrough and automation
Results 61 to 90 of 2358
@VideoFanatic: I used the default settings, set Audio&Video to passthrough / passthrough all and ended up with a 1.79GB m2v file and a 106MB ac3 file.
-> you probably changed some of the default values -
Forgot to tell you my settings: http://i384.photobucket.com/albums/oo290/holygamer/HybridSettings_zpsb5292d72.png
I tried with your values and got the following calls:
for the audio extraction:
then a rename call:Code:ffmpeg -y -threads 8 -i "H:\Eastern CW May 10 1994.mpg" -vn -acodec copy -map_metadata -1 -metadata handler_name="Hybrid 2013.05.27.1" "H:\Output\aid_128_00_22_20_5610_21.ac3"
the video call:Code:H:\Output\aid_128_00_22_20_5610_21.ac3 ### H:\Output\Eastern CW May 10 1994.ac3
and another rename call:Code:ffmpeg -y -i "H:\Eastern CW May 10 1994.mpg" -vcodec copy -an -map_metadata -1 -metadata handler_name="Hybrid 2013.05.27.1" -f mpeg2video "H:\Output\00_22_20_5610_23.m2v"
Whole thing went fine and I ended up with:Code:H:\Output\00_22_20_5610_23.m2v ### H:\Output\Eastern CW May 10 1994.m2v
Eastern CW May 10 1994.ac3 and Eastern CW May 10 1994.m2v
using flac for the audio I got these calls:
for the extraction:
for the audio reencoding:Code:ffmpeg -y -threads 8 -i "H:\Eastern CW May 10 1994.mpg" -vn -acodec copy -map_metadata -1 -metadata handler_name="Hybrid 2013.05.27.1" "H:\Temp\aid_128_00_25_38_2610_25.ac3"
a cleanUp call which deletes the extracted audio:Code:ffmpeg -y -threads 8 -i "H:\Temp\aid_128_00_25_38_2610_25.ac3" -c:a flac -compression_level 5 -sample_fmt s16 -ac 2 -ar 48000 "H:\Output\iId_17_aid_128_00_25_38_261025.flac"
a rename call which renames the audio:Code:"H:\Temp\aid_128_00_25_38_2610_25.ac3"
a video extration call:Code:H:\Output\iId_17_aid_128_00_25_38_261025.flac ### H:\Output\Eastern CW May 10 1994.flac
and a video rename call:Code:ffmpeg -y -i "H:\Eastern CW May 10 1994.mpg" -vcodec copy -an -map_metadata -1 -metadata handler_name="Hybrid 2013.05.27.1" -f mpeg2video "H:\Output\00_25_38_2610_29.m2v"
which too worked fine and gave me:Code:H:\Output\00_25_38_2610_29.m2v ### H:\Output\Eastern CW May 10 1994_new.m2v
and
the _new is there because Eastern CW May 10 1994.m2v already existed
What do your calls look like? (disable "Jobs->Minimize job command lines" to disable) -
This is very strange. It seems to be working now like you said. I've not changed any settings.
@blu7: fixed the drag&drop thing, if you tell me what OS you use I can send you a test version.
Playing around with mkv and ass, I realized I got no decent sample, so if someone has a small sample mkv file with the following characteristics:
a. < 10MB
b. ass subtitles
c. attached fonts (multiple) which are used and recognizable and do not by default ship with windows
-> please attach it or send me a pm with a link.
thanks
Cu Selur -
First, congratulations for software
I have the actual latest version of Hybrid (2013.05.22) and there is a problem with file avi (xvid) creation. If I mux file audio and video with the software, don't create the xvid but the divx for the setting -ffourccDX50 in the call "creating file avi" into the Job Queue, I think... In this way I can't watch it if my Blu-ray and DVD Players can't play DivX. But if I set "No multiplexing and splitting" in Config-->Output-->Container Settings and mux the encoded file audio and video with another program such as AviDemux or Virtualdub the problem is solved. These are the differences:
Files muxed with Hybrid:Hybrid.txt
Files muxed with AviDemux:AviDemux.txt
Oh, and also if I set Mp3 CBR in Audio the result is VBR with Hybrid. Mux with another software and also this problem is solved...
Can you solve this problems in the next version? -
A. Thanks
B. This is the problem. For MediaInfo is constant but for the DivX Player or some program on PC (VirtualDub for example) Audio is VBR
This report is created with AVInaptic:By AVInaptic.txt -
It's just a reporting for this audio encoding error. In my case mp3 CBR or VBR is the same thing
Made some changes, please check if the attached file works okay for you?
Now the XviD video is ok
For the Audio files... are both VBR but no problem for this.
Does the attached file work better for you? (this time mencoder is used for muxing; Hybrid uses mencoder for muxing if one one audio stream needs to be muxed, since mencoder can't handle multiple audio with delays properly, see: http://forum.selur.de/post3080.html)
Cu Selur -
With many programs there are problems with this file: "invalid avi file: the main movie block is missing", "Could not open the file", "Format Error", etc...
Blue-ray and DVD Player can't play it and both are blocked... Same for the DivX player... -
That is probably because of the video stream,.... it's one of my test samples and not intended to be hardware compatible with anything.
strange, I'll reencode the file seems I broke something somewhere,..
reencoded the video stream,..Last edited by Selur; 31st May 2013 at 15:07.
In this second test no problem except audio mp3. But the difference with the first is undoubtly the xvid version...
second file was reencoded so the video stream changed.
Regarding the muxing, you can try if it helps to update the ffmpeg version (there have been a bunch of updates since the last Hybrid release) -> http://ffmpeg.zeranoe.com/builds/
may be with the latest version the headers are fine, if not sadly there isn't a thing I can do,..
Look, I tryed the latest version of ffmpeg but nothing. Anyway the problem was the XviD that was become DivX in the mux step and seems that it can be solved. For Mp3 there's a problem always with the mux but it's really CBR since if you mux with another software there isn't this problem, sooo...
1 File out of 50 won't Demux
I did a batch demux of 50 MPEG2s with passthrough video and AC3 to FLAC conversion. One MPEG2 file gave an error message saying it couldn't rename the flac file since it didn't exist. The demux said "Aborted" in the demux window and the queue would not finish demuxing until I OK'd the message. No files were created for the MPEG2 that gave the error message.
I reported this to you in the past but you couldn't do anything about it as I couldn't replicate the problem as when I processed the file again, it worked. Is there any way for me to give you a log file?
Here are all the settings I use. -
Log file doesn't help. I need a debug output (see: http://www.selur.de/support).
Log file simply doesn't contain useful data for me.
-> If you can reproduce the problem when trying to remux the video and reencode the audio to flac, create a debug output and post it here or send it to me.
If you can't reproduce the problem I can't help, sorry.
Cu Selur
vp9 vs x265 vs DivX265
By deadrats in forum Video ConversionReplies: 14Last Post: 28th Jun 2015, 09:48 -
HEVC-x265 player in linux?
By racer-x in forum LinuxReplies: 4Last Post: 20th Mar 2014, 18:10 -
Hybrid [x264/XViD - MKV/MP4] Converter Support Thread
By Bonie81 in forum Video ConversionReplies: 6Last Post: 8th Jan 2013, 03:53 -
VP8 vs x264
By Selur in forum Video ConversionReplies: 14Last Post: 14th Apr 2012, 07:48 -
How often do you reinstall your operating system(windows,mac,linux etc..)?
By johns0 in forum PollsReplies: 28Last Post: 22nd Jan 2011, 17:14
