hello, sorry if i get the wrong topic forum
i have an AC Ryan DVR, so i record stuff from TV using it
the file is recorded on MPEG-2 format
but when i want to put it to DVDs i encounter problem, because these recordings are somehow Copy-Protected
so when i want to Re-Record using a DVD Recorder, it wouldn't record
when i cut and edit with my computer, and want to use some software to make into DVD, it wouldn't work
when i try to convert it to other format (MKV), it still give the same problem
the bottom line is, this copy-protected thing is there
and i believe there is no setting on the DVR to turn it off
so i can play it again to watch, but cannot make DVD from it
is there any software to get rid of this copy-protection thing so i can make it into DVD?
thank you
Welcome to the digital revolution. Your entire setup has been carefully designed to prevent you from doing what you want to do. There is no workaround. You can try feeding your DVR's output thru a Hauppauge HD PVR and into your PC (but you have to buy the PVR to try it out). At this stage, it likely won't work. In the future you could use the component outputs from your cable box (if your cable company hasn't disabled them) to record thru the Hauppauge product into your PC, directly to HD (BluRay). The Hauppauge unit ignores most copy protection schemes. The downside is, the PC you record to needs better edit and authoring software (some of which is free), and a good DVD/BluRay burner. Another problem: if you want to record something at 2:30 AM, you leave your PC running all night.
The first thing you'll notice when working these videos on your PC is that the HD from your cable provider is a lot better than the old VHS (and will probably look better thru component than thru HDMI), but it's a long way from a retail DVD or BluRay. Another benefit of the digital revolution was to increase profits by broadcasting at low bitrates.Last edited by sanlyn; 21st Mar 2014 at 20:19.
All true. And if you're a serious video hobbyist, that low bitrate cable stuff will only get more painful as you gain experience.
I use my Hauppauge HD-PVR more for time-shifting and less for saving videos to edit and archive, the reverse of what I thought I would do when I bought it. If something comes out on Blu-Ray that I think is worth having, I end up buying it.Pull! Bang! Darn! -
Out of curiosity what kind of anti-copy protection do they use in these DVR (never had one so..)
If it's macrovision it could be easy i believe*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
Macrovision is part of it. But you can dub using a hauppauge hd pvr. I have many times with my motorola dvr from comcast.
The other part is a file encryption that would make the recorded show garbage if you somehow managed to copy it off the harddrive. I'm pretty sure that type of encryption is essentially unbreakable. At least for the average video person.
I'm sure you can also dub using a dvd recorder. However your mileage may vary. It depends on how sensitive it is to any flags the dvr might have. THe hauppauge hd pvr does pretty much ignore most if not all of those types of flags. Of course thats real time analog dubbing. And you might not be able to use the component cables if your provider has disabled them. That should still leave rca or svideo for outputs however.
edit - jagabo strikes first again!
My Dvd Video Disc is Protected, Couldnt copy the files..... ^_^
By syaoran7li in forum DVD RippingReplies: 21Last Post: 20th Apr 2012, 20:05 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
Archos AV700 and 'Copy protected Video files'
By florent_g in forum Video ConversionReplies: 11Last Post: 8th Nov 2008, 10:14 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 11:23
