I'm trying to create a XVCD from an AVI. I followed the "how to" on this site using TMPGEnc.
The XVCD plays and the image quality is great, except when the subject is moving or the camera is panning. There is "ghosting" on the screen (image is blurred when there is movement).
Here are the specs I used(following the tutorial on this site):
source AVI: 720x480 29.97fps from DV footage
TMPGEnc settings: ("video" tab) 720x480, 4:3 525 line (NTSC) aspect ratio, 29.97 fps, CBR 2500kbps
("advanced" tab) non-interlace (progressive), 1:1 (VGA) source aspect ratio, Full screen (keep aspect ratio) video arrange method
("system" tab) MPEG-1 Video-CD (non-standard)
Am I missing something here? I tried dropping the fps to 23.976 with worse results. Should the video source type be Interlace instead of non-interlace?
Thanks for your help,
d
I don't know if this will help, but you can try reading under the DVD Players Compatibility List to see what the maximum bitrate for X-VCD is for your DVD player.
Problems with an avi to MKV conversion
By Paxmilitaris in forum Video ConversionReplies: 0Last Post: 21st Oct 2011, 15:11 -
DVD to avi conversion problems
By carlmart in forum Video ConversionReplies: 6Last Post: 19th Apr 2011, 15:01 -
File conversion problems AVI to Divx
By kaptainm in forum ffmpegX general discussionReplies: 2Last Post: 10th Aug 2008, 20:21 -
Having problems with my .MKV conversion (to .AVI)
By triptiks in forum ffmpegX general discussionReplies: 2Last Post: 16th Jul 2008, 23:29 -
By olson311dude in forum Video ConversionReplies: 14Last Post: 9th Oct 2007, 05:27
