Just a quick question, Can i burn .avi/mp4/mkv etc to blu ray media and play it in a blu ray player like if i were doing the same with dvd?
Results 1 to 11 of 11
It depends if the blu-ray player supports avi mp4 mkv on the bd media.
Ok if i copy these files to BD does it have the same file structure as a dvd?
You can convert it to a bd video / structure and it will work on more blu-ray players. Like you are converting to dvd-video(VIDEO_TS FOLDER). Use https://www.videohelp.com/tools/sections/all-in-one-blu-ray-converters
No.
Unless you are not being clear on exactly what it is you want to do
I have burned several MKV's to BDRE, bluray rewrtitable, as just a data disc and they play fine.
As long as your bluray player will play the format.
And I have never tried an AVI/Xvid on BDRE before (I usually use a usb thumbdrive) but i don't see why it wouldn't. -
I guess i could just try it for myself BD media is getting cheaper all the time. Thanks for the replys and info.
can i burn straight mkv files to dvd to play in a blu-ray player that supports mkv, as the mkv file is less than 4gig in size.
tried it, doesn't seem to work -
Edit:
I just saw your posts in the other thread. If MKV playback was added to the player via a firmware update then all bets are off. Most MKV capable players will play MKV files from either DVD or Bluray discs, or via USB these days, but if MKV playback was added to your player as an after-thought via a firmware update, it's MKV playback abilities might be fairly limited.Last edited by hello_hello; 21st Apr 2012 at 00:59.
sorry, I must have clicked on the similar threads and posted it accidently, thinking I didn't do it properly the first time
You can copy any format to a BD and play it in a bluray player as long as it is supported. The player will read the disc as it would a dvd and basicly is the same process as burning a DVD. Thank you for the replys.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 03:35 -
Copyed Blu ray won't play in blu ray player
By gweedow in forum Video ConversionReplies: 6Last Post: 13th Jan 2011, 14:58 -
Blu-Ray player that plays MP4 and/or MKV from disc (not only USB)?
By cosmin in forum DVD & Blu-ray PlayersReplies: 6Last Post: 7th Dec 2010, 22:49 -
Introducing Ray in Blu Rendr - Digital Media Receiver Blu-ray Disc
By rayinblu in forum Newbie / General discussionsReplies: 6Last Post: 15th Apr 2010, 09:37
