What do people do with mpeg-1/2 video mpgv at 59.94 frames per second?
I have had some issues with both playing this type of video and editing or converting this video. When I edit or convert this video format the sound comes out completely unsynchronized. What do you people usually do with this type of video format?
I have recently discovered myself the mpeg-1/2 mpgv@59.94 is commonly known to me as HDV. Sony and Apple worked together to make their systems perform flawlessly. I'm sure other companies were involved, but I've been committed to Sony and Apple for some time, so I just went with it. Anyway, miniDV was the first format, in SD, to really utilize FireWire (IMHO). There are as many protocols as there are codecs, but the point here is to highlight the HD format: HDV. HDV uses FireWire and, like miniDV/DV Cam, it uses about 5 minutes/1G, or about 12G/hour. Additionally, HDV encompasses other HD formats, like 720P and even European formats.
Anyone with an Apple FinalCutPro system capable of working with HD files (V5 and up, that I know of) should be able to work with that file with ease. -
To work with that file on your system will require HDV codec and QuickTime. Not sure about the windows side of things, but QT Pro for Windows should include the HDV codec so you can use it. It may not play in real-time in your editing software, so you may need to convert it to a format that is natie to your system.
Your computer details say you use a PC, but the mpgv description is most often used by Apple-oriented software. VLC is the only software I can recall using on my PC that describes my interlaced MPEG-2 video in an .mpg file as mpgv at 59.94 frames per second. Everything else I use that provides video information says the same video is MPEG-2 at 29.970 frames per second. (59.94 fps usually means interlaced video at 59.94 fields per second rather than 59.94 frames per second. It is the same as interlaced video at 29.97 frames per second. 720p video in NTSC countries is the only common format that uses 59.94 frames per second)
TV captures in .ts files will often loose synchronization after editing or converting. As jman98 said VideoReDo is the best program I have tried for editing captured TV shows in MPEG-2 .ts files.
If it isn't a .ts file, try opening the video using MediaInfo and post the report from its text option. Also, what file extension does it use and what software have you tried to edit or convert it? The source of this video (camera file, etc.) could be useful too. -
59.94i = 29.97fps interlaced
Often shorthanded to 60i.Want my help? Ask here! (not via PM!)
Thank you. It's been awhile since I tried to work with that movie. I was trying to edit out the first 7 minutes and the results were desynchronized sound. I'll try it again sometime soon and see what happens. And yes, I'm using a PC.
decoding mpeg video into frames say I,P,B frames
By abeer in forum ProgrammingReplies: 44Last Post: 6th Oct 2012, 09:24 -
Blender Tutorials for the Video People
By tin2tin in forum Latest Video NewsReplies: 20Last Post: 10th Jan 2012, 15:20 -
Burn Errors due to MPGV ?
By mrlewp in forum Authoring (DVD)Replies: 1Last Post: 21st Sep 2010, 20:54 -
Smart video/audio people please help with this one.
By Peggasus in forum Software PlayingReplies: 6Last Post: 10th May 2010, 00:17 -
problem with shadowed people in video
By lucifron in forum EditingReplies: 2Last Post: 3rd Nov 2008, 14:06
