Hi there, I hope someone out there can help a somewhat seasoned newbie with a strange problem.
I better start with the specs of my system. It comprises of:
Athlon XP2000+
256MB DDR RAM
10Gig Maxtor 7200 HDD
60Gig IBM 7200 HDD
AIW RADEON
SB LIVE
(Capturing from Digital TV and Video on Demand)
So, I'm capturing seemingly well in Win98SE, with Virtual Dub and Huffy codec at 720x576 with about 10%-12% CPU usage and thankfully, about 1 dropped frame for every 15-20 mins of captured footage. Now, trying the same thing in Win2000 or XP creates a strange audio problem. The video capture is absolutely fine with NO dropped frames at all, but a strange, static clicking sound akin to that heard from Vinyl records runs throughout the capture. Yet, this never occurs when capturing with 98. Has anyone ever come across this problem and does anyone have a solution? Any help would be greatly appreciated. Thanks!!!
does your mother board have a via chipset? if so i had a similar prob i fixed it with the via pci latency patch you can get it at viahardware.com
I get the same thing with my virtualdub cap of Angel Eyes VHS on xp pro. It has noticeable static in the sound going on and off. Is this some sort of macro blocking on the sound? radeon64vivo.
Hmm... how strange... I don't remember reposting this... as I posted the original question about a month ago.... hmmm....
Anyway, as it's here, unfortunately the latency patch didn't change things, neither did swapping the PCI ports for the sound card...
So, I'm sticking with 98SE as it's perfect for all my capture needs. I would still love to move on from it though, to XP, but I guess I'll have to wait till I get a new capture card.
Thanks for the help anyway!!!
I have a strange problem and I would like to ask if is possible to be solve
By takis76 in forum SubtitleReplies: 1Last Post: 8th Dec 2010, 14:53 -
Help with Strange Problem?
By Mitchum22 in forum Newbie / General discussionsReplies: 4Last Post: 21st Jun 2010, 22:10 -
Very strange VHS to PC capture problem
By fredhoward in forum Capturing and VCRReplies: 45Last Post: 9th Feb 2010, 08:30 -
Internet Explorer 6 problem on Windows 2000
By edong in forum ComputerReplies: 17Last Post: 23rd May 2008, 00:04 -
Looking For A Windows 2000 Compatible Video Capture Device
By acid_burn in forum Capturing and VCRReplies: 16Last Post: 29th Nov 2007, 11:42
