I know it's almost impossible to remove hardcoded subtitles. But I would like to know how can I figure out if a subtitle is hardcoded/embedded in a video file or not.
And if not, I understand it is possible to remove it, right?
URGENT is everything someone INCOMPETENT did not ON TIME and want you KILL yourself to do in RECORD time.
You don't say what format your video is in, so everything is just a guess. Somewhere in your container is a raw video file. Extract that and see if the subtitles are in it. If so, they are hardcoded.
It is not impossible to remove them, but it is very much IMPRACTICAL to do so.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
There's always MediaInfo. It'll list subtitle streams in a video, as long as they're not hardsubbed. Of course, if whatever player you're using supports it, and/or you're using DirectVobSub, you can also try switching the subtitles off.
...and if the subtitles look like they're part of the video image, are perhaps more pixelated/blurred on the edges than you'd expect a soft-subtitle renderer to have the subtitles look, they may be hardsubbed.
If cameras add ten pounds, why would people want to eat them? -
Changing font size/color for hardcoded subtitles
By JMantis in forum SubtitleReplies: 4Last Post: 6th Mar 2011, 19:34 -
How can I make subtitles hardcoded and change font? (avstodvd)
By striker9 in forum SubtitleReplies: 6Last Post: 1st Sep 2010, 02:32 -
How to add hardcoded subtitles to WMV using ffmpegX
By Vitoarc in forum ffmpegX general discussionReplies: 0Last Post: 12th Mar 2010, 11:42 -
looking for software that will extract hardcoded subtitles from mpeg1
By jimdagys in forum SubtitleReplies: 2Last Post: 3rd May 2009, 09:10 -
Extracting hardcoded subtitles-does anything actually work?
By kpic in forum SubtitleReplies: 3Last Post: 2nd Jun 2007, 06:34
