Hello. First of all, i'm going to apologise if this is not the correct place on the forum to post this.
Now to my issue.
I have a video in mkv format and i used multiavchd like i have used many times before, placed it on my external HDD and play it on the PS3, but with this specific video file when i did the playback i had video but no audio.
The audio format is 2channel AC3.
I searched a little bit more and i understood that maybe i should convert the AC3 to AAC and then join audio and video and try again.
But what software should i use to extract the audio? And what software should i use to convert it? And finally, what do i use to mux it all together?
I saw an option in MultiAVCHD when i add a video file, go to its properties i can add or remove audio files, could i add it there and make multiavchd do everything?
Thank you for the help.
ac3 is what you should use for avchd.
I would go back to your source material and try again.
If it were dts I'd suggest converting as apparently its hit or miss with dts on avchd (though your dts enabled amp should play it back its whether or not the ps3 would send it from the avchd properly as its not part of the avchd spec - but it may or may not work).
eac3to can convert a lot of audio source - not sure about an aac output but I wouldn't be surprised if it can. But like I mentioned reconvert again with your original source and leave as is. There is a chance it was just a glitch on the project.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
You should NOT convert to AAC. AAC is not supported for AVCHD so multiAVCHD will convert it, making it have no purpose to deliberately convert to AAC.
multiAVCHD has been abandoned by its creator and it may have bugs in it. If you do not need menus then I suggest that you use tsmuxer to create your AVCHD this one time and see if what it makes is OK. Go back to multiAVCHD in the future and don't worry about why this time it didn't work.
Also, play the AVCHD file on your PC that multiAVCHD produced. Your computer should be able to play 2 channel AC3. If you don't hear anything, try installing the free VLC player. If there is no sound with VLC then you will at least know that it is not an issue with the PS3. -
Thats too bad. I am not a frequent avchd maker but I have used it for that purpose.Originally Posted by jman98
Is there an alternative out there? I know the arcsoft software that comes with the hauppauge hdpvr is a bit limiting in features (and I haven't upgraded or bought the "full" version so i don't know if there is an improvement for arcsoft).
I don't need a pay version of software but suggestions for avchd authoring would be appreciated. In the end I guess no frills file only output from tsmuxer would suffice but I would like options.
Thanks.
Sorry for the detour
There's no real free alternative to multiAVCHD. I'd love to use it more, but I'll make the same complaint I have for GUI for DVDAuthor. The software seems capable of an incredible amount of things but all the documentation is woefully inadequate. However, if you happen to have any links to multiAVCHD documentation that you think actually is useful, I'd love to know where it is. Perhaps I've missed it somehow. I can at least make very very simple text menus with GfD and I can't even get that far with multiAVCHD.
Thats too bad. I guess its too much of a niche market for freeware developers to dive into. They must want to go into full fledged bluray programs rather than avchd.Originally Posted by jman98
It has been awhile since I've used it but here are some links to check out for it:Originally Posted by jman98
http://multiavchd.deanbg.com/tutorial.php
https://www.videohelp.com/guides?searchtext=multiavchd&tools=&madeby=&formatconversions...or+List+Guides
http://www.google.com/url?q=https://forum.videohelp.com/threads/333678-multiAVCHD-menu-...CCBnfychbl542g
http://www.google.com/url?q=https://www.videohelp.com/guides/brief-tutorial-on-multiavc...e3_8d8Mo8fFb2g
http://www.google.com/url?q=https://forum.videohelp.com/threads/343852-Cannot-get-multi...6AFFHVfsH86QCQ
http://www.google.com/url?q=https://forum.videohelp.com/threads/324839-multiAVCHD-Menu&...MfcwMLHl0fdGnQ
I'm sure you've looked at some of these. I hope one or two might lead you to the right path.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
multiAVCHD audio bitrate?
By morghe-sokhari in forum Newbie / General discussionsReplies: 0Last Post: 16th Feb 2012, 10:11 -
Problem with creating AVCHD file for ps3 using MultiAVCHD. Please help...
By Mike789 in forum Authoring (Blu-ray)Replies: 0Last Post: 22nd Dec 2011, 16:28 -
Audio gain in MultiAVCHD
By Zetti in forum Video ConversionReplies: 0Last Post: 16th Sep 2010, 13:46 -
Multiavchd disc wont play in PS3
By cougarve in forum Authoring (Blu-ray)Replies: 28Last Post: 30th Aug 2010, 09:28 -
1st VOB Audio Fine on PS3, 2,3,4 VOB No Audio on PS3
By raerae28 in forum Media Center PC / MediaCentersReplies: 6Last Post: 25th May 2008, 05:10
