I have an XFX GeForce 8200 Motherboard, an XFX GeForce 9500GT Video Card. I want to use the HDMI port on the motherboards integreted video card for my TV, and I want to use the DVI port on the PCI Card for my monitor. I am using Windows XP, is there any way to run both cards at once? I have updated drivers for the motherboard but it appears that XP doesn't even see the motherboards video card. Any help would be great, Thank you.
Go into your MB bios and see if the igp has been disabled,some MB do that by default when an external video card has been plugged in,enable it if that's the case.
Well, we decided that the motherboard has DVI and HDMI both so we took the PCI card out. The DVI is displaying to my monitor no problem but the HDMI is still not working, If the HDMI is plugged in when I boot up neither the TV or the Monitor have any display. This should be working right? Both ports are on the same card. Is it a problem with XP?
Check with the nvidia control panel in your start menu and there should be a setting to output the hdmi and dvi as cloned or extended.
PCI or PCIE video capture card
By bigjimmpls in forum Capturing and VCRReplies: 11Last Post: 1st Jun 2010, 13:36 -
Look at this pic Do I need a PCI or AGP video card in my PC
By marionr26 in forum DVB / IPTVReplies: 4Last Post: 12th Feb 2010, 01:34 -
Does PCI Express Graphics card always disable onboard video ?
By SingSing in forum ComputerReplies: 4Last Post: 15th Oct 2008, 14:59 -
getting new PC: use onboard video or PCI-e dedicated video card?
By alandla in forum Newbie / General discussionsReplies: 18Last Post: 27th Feb 2008, 11:13 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
