Hi,
I want to convert my old Video Tapes to VCD.
What software can I use to perform a continue capture so I can capture the tape from beginning til end without manual intervention? I know there is a file size limit(2g per file) on Win98 (my OS) so is there a software that can automatically create another file once it reaches the 2Gig limit? Thank you in advance.
Regards,
anon
yes,
virtual dub will allow a you to break the 2gig file limit. just click on the tools link on the left hand side of the forum. -
Thank you for that, I already have Virtualdub, but it can only capture 1 file and doesn't automatically create another file once it reaches the 2gig. What setting should i be using in Virtualdub? Please advise thanks.
It's ok, I've got it now, should have read the help file in Virtualdub first! Thanks again,
Video Capture software question
By kgingreen in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2010, 14:07 -
Question about avi file size limit for DVD players
By jimdagys in forum DVD & Blu-ray PlayersReplies: 6Last Post: 10th Dec 2009, 04:12 -
Video Capture Question
By wcwman18 in forum Capturing and VCRReplies: 5Last Post: 3rd Aug 2009, 00:05 -
Question how to change TV card max file limit of 4.1 GB
By jimdagys in forum Capturing and VCRReplies: 2Last Post: 25th Nov 2008, 08:47 -
Sony Video Capture 6 (Vegas MS) hard drive max size limit?
By distendo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Jun 2008, 10:02
