I've ripped one of my bluray discs that have a DTS-HD main audio track, and I want to include both the DTS-HD audio and a second AC3 5.1 audio in an mkv file for compatability. Problem is, I've already encoded the movie to MKV and what I thought would be 5.1 was just 6 channel discrete, and it's being read by my receiver as 2.0. How can I take the ripped m2ts file, rip out the DTS-HD track and convert it to a dolby digital/surround 5.1 so I can re-mux it into the MKV file?
Thanks.
Solved it after extensive research and trial/error.
Used tsmuxer to demux the dts-hd (and at the same time, convert it to plain DTS). Then used eac3to to convert to AC3. Had problems with the second step for a bit because it refused to convert directly. Had to first downsample it from 6.1 to 5.1 using -down6 before it would let me do the conversion.
Difference Between DTS 5.1 & Dolby Digital AC3 5.1
By dorababu in forum AudioReplies: 8Last Post: 31st Mar 2013, 22:31 -
MKV files with Audio in DTS need to convert audio to AC3
By THEHNIC in forum AudioReplies: 5Last Post: 3rd Jun 2011, 09:17 -
Dolby ac3 to dts
By skorpinok in forum AudioReplies: 10Last Post: 9th Dec 2010, 00:01 -
trying to convert avi w/ dolby ac3 audio and it wont sync right
By cduval04 in forum Video ConversionReplies: 2Last Post: 14th Jan 2009, 19:40 -
How to convert DTS audio to AC3?
By Henderson in forum AudioReplies: 1Last Post: 26th Jul 2007, 18:33
