I have a Phillips DVP5990 and when I plug in my flash drive the files aren't in alphabetical order. Im wondering why they aren't??
Does anybody know how the dvd player sorts them? There doesnt seem to be any kind of pattern that I can see.
When I look at the flash drive contents from my computer have them sorted by name. I have also removed everything except the title:
S01E01
S01E02
S01E03
etc...
But when I plug in my drive they're out of order instead of 1-10.
Anybody have any idea how the player sorts them or any help at all to help shed light on this?
Obviously I want them in order so that I can watch my shows in order.
I figured it out.
They're sorted by when they're added onto the drive. A quick fix would be to just put them on the drive in the order you want them in. There ya go.
Thanks, and you're welcome. -
...or, just use a drive/folder/file-sorting utility, like FolderSort (I think I posted a copy in a different post (for the modified 5990 firmware), as IIRC, the homepage is gone, so try searching for the name), and sort the files by alphanumerical order.
Edit: It's this post. Of course, there are a handful of other alternatives, too.If cameras add ten pounds, why would people want to eat them? -
Thanks. I'll actually be giving this a try tomorrow. I'll let ya know how it goes.
The program actually worked. But it would be nice if I could just set the drive to always just sort by name. But the program is better than nothing. Thanks.
Help with Phillips DVP5990/F7
By jwishy in forum DVD & Blu-ray PlayersReplies: 7Last Post: 27th Apr 2010, 23:33 -
Phillips DVP5990/F7 and .AVI - video is Ok, but no sound
By PaulGor in forum DVD & Blu-ray PlayersReplies: 10Last Post: 16th Apr 2010, 12:12 -
Another Phillips Question DVP5990/F7
By jwishy in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Feb 2010, 10:44 -
Philips DVP5990 Flash Drive Problem: Empty Card
By stormko in forum DVD & Blu-ray PlayersReplies: 7Last Post: 24th Sep 2009, 07:08 -
Anyone else have a issue with the phillips DVP5990/37?
By Gareee in forum DVD & Blu-ray PlayersReplies: 6Last Post: 5th Dec 2008, 08:16
