Hi
I recently downloaded an AVI video file and used (Any Video Converter) to convert the file to (DVD Video PAL Movie MPG) After the file had been converted i then tried burning it to disc so as to watch on DVD. But when inserting the disc in my Macs DVD Player the disc won't play, it confirms "disc is not supported" i clicked info and it tells me the format is "Mac OS Extended" I don't understand this as i converted the file to DVD Video PAL Movie MPG) why has the file not burnt to this format?
Mac OS X Leopard 10.5.
	You can not simply burn a mpg file to a disk as a dvd. You must 'author' a dvd.
 Since you appear to be using a mac, take a look at the mac tools under 'Tools/Software' to the left of where you read this reply.
	Thread moved to the mac forum where you can get more help. I think,therefore i am a hamster.
	What, exactly, are the folder and file contents of the disc you burned?
 A correctly-authored DVD-Video disc should have a VIDEO_TS folder at the root of the disc, with .VOB and .IFO files in it. See What is DVD? - VideoHelp.com for more details.If cameras add ten pounds, why would people want to eat them?
	ohhhhhh how stupid of me, after converting the file from AVI to MPEG i was automatically hitting "burn file to disc" under the file tab using the Mac. i apologize for my lack of knowledge in DVD authoring.
 I now have the Burn application and the file is now burnt to the correct standard, all is well.
 Thanks.
  Compress PAL DVDs to watch on WD TV Live Hub...By nharikrishna in forum Video ConversionReplies: 6Last Post: 27th Apr 2012, 07:13
  using NTSC TV as external monitor to watch PAL dvds played on laptopBy billybadbreaks in forum Newbie / General discussionsReplies: 3Last Post: 1st Mar 2009, 15:27
  I want to watch PAL formatted, Region 2 DVDs in the USA.By Lori in forum DVD & Blu-ray PlayersReplies: 18Last Post: 10th Jul 2008, 20:39
  Want to watch rip'd DVDs by hooking up MacbookPro to TV. Some audio Q's...By marklight in forum MacReplies: 1Last Post: 23rd Apr 2008, 19:53
  Anyone use a Multimedia hard drive to watch DVDs/videos on their TVBy Lothar1974 in forum Media Center PC / MediaCentersReplies: 1Last Post: 25th Oct 2007, 18:37
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
