  1. Member ozok's Avatar
    Oct 2011
    Turkey
    TX264 is a GUI for x264, ffmpeg, mkvmerge, mkvextract, mp4box, faac, neroaacenc, qaac, oggenc2, aften and flac. It is written in Delphi.
    Some features:
    -All basic x264 options (profiles, crf, bitrate etc)
    -64bit support
    -10bit encoding depth support
    -Advanced x264 options
    -Resizing and cropping
    -Split according to size or time
    -Preview filters and encoding options applied
    -Encode audio streams to aac, ogg, mp3, ac3 or flac
    -Apply audio filters (resample, normalize, volume, channel downmix, DRC)
    -Copy chapter info from mkv/mp4 source
    -Mux encoded content to mp4 or mkv
    -Mux all external or internal subtitles to the output mp4/mkv
    -Pass custom options to tools
    -Detailed info about selected file
    Screenshots:
    Bug reports and suggestions are more than welcome.
    Download page: http://tx264.sourceforge.net/ just extract 7zip archive and run.
  2. Member ozok's Avatar
    Oct 2011
    Turkey
    What's New:
    --0.2
    -Added: Support for qaac
    -Added: Support for oggenc
    -Added: Support for aften
    -Added: Console outputs are added to log right after that process is finished
    -Added: TX264 now remembers last opened directory
    -Fixed: NeroAacEnc profile could not be set problem
    -Fixed: A few minor problems
    -Updated: JVCL to 3.45
    -Updated: MediaInfo.dll to 0.7.55
    -Updated: FFmpeg to N-39494-g41a097a
    -Updated: mkvmerge to 0.5.5
    -Updated: mkvextract to 0.5.5
  3. Member ozok's Avatar
    Oct 2011
    Turkey
    Update:
    --0.8.4
    -Added: Support for rmvb
    -Fixed: Encoding failed if video's ID was 0
    -Fixed: Audio copy failed if file had more than one audio stream
    -Fixed: Progress values will be shown in taskbar
    -Updated: FFmpeg to 07-26-212 build from ffmpeg.zeranoe.com
    -Updated: x264 to rev 2208
  4. Member ozok's Avatar
    Oct 2011
    Turkey
    Update:
    --0.9.6
    -Fixed: Couldn't open avs files (thx to MerolaC)
    -Fixed: Files without audio streams or avs files caused some problems (thx to MerolaC)
    -Fixed: Vobsub streams couldn't be muxed to output
    -Fixed: Audio extraction progress wasn't shown
    -Changed: Skin
    -Improved: GUI's CPU usage while encoding is lowered
    -Removed: CPU usage bar
    -Updated: x264 to rev2309
  5. Member ozok's Avatar
    Oct 2011
    Turkey
    Update:
    --0.9.7
    -Added: Encoding time will be shown in the log
    -Added: 64bit FLAC.exe
    -Added: Tx264 will now write version info file to its own folder
    -Added: Option to set encoder priorties (thx to XanaMuui&Ruriko)
    -Fixed: A possible error where source files were deleted
    -Updated: x264 to rev2345
    -Updated: MediaInfo to 0.7.64
    -Updated: MkvToolNix to 6.3.0
    -Updated: FLAC to 1.3.0
    -Updated: AlphaControls to 8.42 Stable
    -Updated: QAAC to 2.19
    -Updated: SoX build with unicode by Lord_Mulder
