Hello,
I am looking for software that will allow me to imbed video into a portion (a specific location of the photo) of a photo, then compile these two formats into another video file.
Does anyone have a suggestion for this?
Thanks!![]()
I'm just starting to use Avisynth, so be gentle:
Using an AviSynth script and VirtualDub.
Save the code as an .avs file and open in VirtualDub.
Base is the image file.Code:Base = ImageSource("C:\users\superuser\desktop\mc0000.jpg", fps=25, start=1, end=1594).converttoyuy2() pip=avisource("C:\users\superuser\desktop\clip.avi").ConvertToYUY2().bicubicresize(120,80) Layer(Base,pip,"add",255,20,20)
It's frame rate is set the same as the motion video and it will have 1594 frames (same as in the motion video).
Pip is the motion video (clip.avi) that plays over the image.
It gets resized to 120x80
The 20,20 numbers in Layer are the x,y coordinates where pip is inserted.
Since Base has no audio, if it's required it can be imported from the Audio menu in VirtualDub. -
Thanks sambat,
I will try that.
What encoding for HD Digital Photo Frame - video with text overlay
By jggretton in forum Video ConversionReplies: 1Last Post: 21st Jan 2010, 12:34 -
Photo Frame - what do these video specs mean? Your interpretation?
By buzzinhornets in forum Video ConversionReplies: 2Last Post: 30th Dec 2009, 12:18 -
Video on Westinghouse Digital Photo Frame DPF-0804
By BobAchgill in forum Newbie / General discussionsReplies: 2Last Post: 9th Dec 2008, 19:58 -
Suggest a video editor for frame-by-frame editing
By ontherocks in forum Newbie / General discussionsReplies: 14Last Post: 24th Apr 2008, 10:36 -
Photo's in video editing
By coondogg97 in forum EditingReplies: 2Last Post: 10th Oct 2007, 11:56
