If you have a big encoding job running, in virtualdub, avs file, and save to avi with compression, and i makes the nice Virtualdub just crashed, and you have used i dont know, 34 hours, can you resume or is it just start from scratch again?
Results 1 to 9 of 9
Not enough information. What are you "encoding" with an avs running in VirtualDub? Can you post your avs script?
DirectShowSource("C:\Users\Admin\Documents\elmebak ken.mpg")
ConvertToYV12(interlaced =true)
AssumeTFF()
SeparateFields()
a=last
clense(reduceflicker=false).merge(last,0.5).clense (reduceflicker=false)
mot=removegrain(11,0).removegrain(20,0).DepanEstim ate(range=2)
take2=a.depaninterleave(mot,prev=2,next=2,subpixel =2)
clean1=take2.TMedian2().selectevery(5,2)
sup1 = clean1.minblur(1).removegrain(11,0).removegrain(11 ,0)
\ .mt_lutxy(clean1,"x 1 + y < x 2 + x 1 - y > x 2 - y ? ?",U=2,V=2)
\ .msuper(pel=2,sharp=0)
sup2 = a.msuper(pel=2,levels=1,sharp=2)
bv22=sup1.manalyse(isb=true, truemotion=false,global=true,delta=2,blksize=16,ov erlap=8,search=5,searchparam=4,DCT=5)
bv21=sup1.manalyse(isb=true, truemotion=false,global=true,delta=1,blksize=16,ov erlap=8,search=5,searchparam=4,DCT=5)
fv21=sup1.manalyse(isb=false,truemotion=false,glob al=true,delta=1,blksize=16,overlap=8,search=5,sear chparam=4,DCT=5)
fv22=sup1.manalyse(isb=false,truemotion=false,glob al=true,delta=2,blksize=16,overlap=8,search=5,sear chparam=4,DCT=5)
interleave(a.mcompensate(sup2,fv22),a.mcompensate( sup2,fv21),a,a.mcompensate(sup2,bv21),a.mcompensat e(sup2,bv22))
sup3 = last.msuper(pel=2,sharp=2)
bv33=sup3.manalyse(isb=true, truemotion=false,global=true,delta=3,blksize=8,ove rlap=4,search=5,searchparam=4,DCT=5)
bv32=sup3.manalyse(isb=true, truemotion=false,global=true,delta=2,blksize=8,ove rlap=4,search=5,searchparam=4,DCT=5)
bv31=sup3.manalyse(isb=true, truemotion=false,global=true,delta=1,blksize=8,ove rlap=4,search=5,searchparam=4,DCT=5)
fv31=sup3.manalyse(isb=false,truemotion=false,glob al=true,delta=1,blksize=8,overlap=4,search=5,searc hparam=4,DCT=5)
fv32=sup3.manalyse(isb=false,truemotion=false,glob al=true,delta=2,blksize=8,overlap=4,search=5,searc hparam=4,DCT=5)
fv33=sup3.manalyse(isb=false,truemotion=false,glob al=true,delta=3,blksize=8,overlap=4,search=5,searc hparam=4,DCT=5)
last.mdegrain3(sup3,bv31,fv31,bv32,fv32,bv33,fv33, thSAD=499)
Interleave()
Weave()
#####interpolate bad frames and residual cleaning
Super = msuper()
bv1 = manalyse(Super, isb=true, delta=2)
fv1 = manalyse(Super, isb=false, delta=2)
bv2 = manalyse(Super, isb=true, delta=3)
fv2 = manalyse(Super, isb=false, delta=3)
global CandidatesForN = mflowinter(Super, bv2, fv2, time=33.3, ml=100)
global CandidatesForO = mflowinter(Super, bv2, fv2, time=66.7, ml=100)
global CandidatesForC = mflowinter(Super, bv1, fv1, time=50.0, ml=100)
last
rx(104,12) #104-116 replaced
AssumeTFF()
SeparateFields()
f1=SelectEven().RemoveDirtMC(100,false).LSFMod(str ength=5)
f2=SelectOdd().RemoveDirtMC(100,false).LSFMod(stre ngth=5)
Interleave(f1,f2)
Weave()
function MinBlur(clip clp, int r, int "uv")
uv = default(uv,3)
uv2 = (uv==2) ? 1 : uv
rg4 = (uv==3) ? 4 : -1
rg11 = (uv==3) ? 11 : -1
rg20 = (uv==3) ? 20 : -1
medf = (uv==3) ? 1 : -200
RG11D = (r==0) ? mt_makediff(clp,clp.sbr(),U=uv2,V=uv2)
\ : (r==1) ? mt_makediff(clp,clp.removegrain(11,rg11),U=uv2,V=u v2)
\ : (r==2) ? mt_makediff(clp,clp.removegrain(11,rg11).removegra in(20,rg20),U=uv2,V=uv2)
\ : mt_makediff(clp,clp.removegrain(11,rg11).removegra in(20,rg20).removegrain(20,rg20),U=uv2,V=uv2)
RG4D = (r<=1) ? mt_makediff(clp,clp.removegrain(4,rg4),U=uv2,V=uv2 )
\ : (r==2) ? mt_makediff(clp,clp.medianblur(2,2*medf,2*medf),U= uv2,V=uv2)
\ : mt_makediff(clp,clp.medianblur(3,3*medf,3*medf),U= uv2,V=uv2)
DD = mt_lutxy(RG11D,RG4D,"x 128 - y 128 - * 0 < 128 x 128 - abs y 128 - abs < x y ? ?",U=uv2,V=uv2)
clp.mt_makediff(DD,U=uv,V=uv)
return(last)
# median of 5 clips from Helpers.avs by G-force
Function Median2(clip "input_1", clip "input_2", clip "input_3", clip "input_4", clip "input_5", string "chroma")
chroma = default(chroma,"process") #default is "process". Alternates: "copy first" or "copy second"
#MEDIAN(i1,i3,i5)
Interleave(input_1,input_3,input_5)
chroma == "process" ? Clense(reduceflicker=false) : Clense(reduceflicker=false,grey=true)
m1 = selectevery(3,1)
#MAX(MIN(i1,i3,i5),i2)
m2 = input_1.MT_Logic(input_3,"min",chroma=chroma).MT_L ogic(input_5,"min",chroma=chroma).MT_Logic(input_2 ,"max",chroma=chroma)
#MIN(MAX(i1,i3,i5),i4)
m3 = input_1.MT_Logic(input_3,"max",chroma=chroma).MT_L ogic(input_5,"max",chroma=chroma).MT_Logic(input_4 ,"min",chroma=chroma)
Interleave(m1,m2,m3)
selectevery(3,1)
chroma == "copy first" ? last.MergeChroma(input_1) : chroma == "copy second" ? last.MergeChroma(input_2) : last
Return(last)
function TMedian2(clip c) {
Median2( c.selectevery(1,-2), c.selectevery(1,-1), c, c.selectevery(1,1), c.selectevery(1,2) ) }
function RemoveDirt(clip input, int limit, bool _grey)
clensed=input.Clense(grey=_grey, cache=4)
alt=input.RemoveGrain(2)
return RestoreMotionBlocks(clensed,input,alternative=alt, pthreshold=6,cthreshold=8, gmthreshold=40,dist=3, dmode=2,debug=false,noise=limit,noisy=4, grey=_grey)
# Alternative settings
# return RestoreMotionBlocks(clensed,input,alternative=alt, pthreshold=4,cthreshold=6, gmthreshold=40,dist=1,dmode=2,debug=false,noise=li mit,noisy=12,grey=_grey,show=true)
# return RestoreMotionBlocks(clensed,input,alternative=alt, pthreshold=6,cthreshold=8, gmthreshold=40,dist=3,tolerance= 12,dmode=2,debug=false,noise=limit,noisy=12,grey=_ grey,show=false)
function RemoveDirtMC(clip,int limit, bool "_grey")
_grey=default(_grey, false)
limit = default(limit,6)
i=MSuper(clip,pel=2)
bvec = MAnalyse(i,isb=false, blksize=8, delta=1, truemotion=true)
fvec = MAnalyse(i,isb=true, blksize=8, delta=1, truemotion=true)
backw = MFlow(clip,i,bvec)
forw = MFlow(clip,i,fvec)
clp=interleave(backw,clip,forw)
clp=clp.RemoveDirt(limit,_grey)
clp=clp.SelectEvery(3,1)
return clp
function R(clip Source, int N)
# N is number of the frame in Source that needs replacing.
# Frame N will be replaced.
Source.trim(0,-N) ++ CandidatesForC.trim(N-1,-1) ++ Source.trim(N+1,0)
function RP(clip Source, int N)
# N is number of the first frame in Source that needs replacing.
# Frames N and N+1(O) will be replaced.
Source.trim(0,-N) ++ CandidatesForN.trim(N-1,-1) \
++ CandidatesForO.trim(N-1,-1) ++ Source.trim(N+2,0)
function RX(clip Source, int N, int X)
# N is number of the 1st frame in Source that needs replacing.
# X is total number of frames to replace
#e.g. RX(101, 5) would replace 101,102,103,104,105 , by using 100 and 106 as reference points for mflowfps interpolation
start=Source.trim(N-1,-1) #one good frame before, used for interpolation reference point
end=Source.trim(N+X,-1) #one good frame after, used for interpolation reference point
start+end
AssumeFPS(1) #temporarily FPS=1 to use mflowfps
super = MSuper()
backward_vec = MAnalyse(super, isb = true)
forward_vec = MAnalyse(super, isb = false)
MFlowFps(super, backward_vec, forward_vec, blend=false, num=X+1, den=1) #num=X+1
AssumeFPS(FrameRate(Source)) #return back to normal source framerate for joining
Trim(1, framecount-1) #trim ends, leaving replacement frames
Source.trim(0,-N) ++ last ++ Source.trim(N+X+1,0)
ColorYUV(gain_y=-12,gain_v=-5,gain_u=+10)
SmoothLevels(0, 0.75, 255, 16, 235, Limiter=0)
SMoothTweak(saturation=0.8) -
I assume you used the script on your other tread it is very slow 0,74 fps average ( how many hours are you trying to encode ).If you have a big encoding job running, in virtualdub, avs file, and save to avi with compression, and i makes the nice Virtualdub just crashed, and you have used i dont know, 34 hours, can you resume or is it just start from scratch again?
Also try to not do other thing with pc while you encode ( it is best to do it overnight while sleep almost all here do the same thing on slow projects ).
The crashing could be related something with your pc CPU ( overheating) or ram or hdd or graphic card
put more info
first use the script on its own ( without filtering in vdub ) maybe some of the filters and filters from the script interact in the bad way use fast recompress in the video tab.
I told you on the other tread that you should do step by step first do the errors then noise reduction then color correction not all at once -
VirtualDub cannot resume after a crash. If you were running a 2-pass encoding, and it crashed during the second pass, you don't need to run the first pass again.
Don't use DirectShowSource() for MPG files, it's not frame accurate. Use DgIndex and Mpeg2Source(). -
but he can use assume 25fps and i think that will solve it right jagabo ? according to wiki that isDon't use DirectShowSource() for MPG files, it's not frame accurate. Use DgIndex and Mpeg2Source().
I think because of the slowness of the script ( at least that was poisen suggestion ) he should first do that, then the filtering in vdub he stuck to much filters in one pass i guess he could also put convert to rg in the end it will less likely make the vdub crash -
The problem isn't the frame rate. DirectShow doesn't guarantee frame accuracy. If you start at frame 0 and move forward frame by frame until you get frame 10 you will get a particular frame. If you then zoom forward to frame 20 and seek backward frame by frame until you get to frame 10 you may not get the same frame you got when seeking forward. This is a bigger problem with editors than with AviSynth scripts but I still wouldn't trust DirectShow.
At first, I wouldn't try to convert an entire video to AVI. DGIndex/MPEG2Source will avoid frame problems. When you open an MPG in DGIndex, you'll notice a view of the video with a slider along the bottom of the viewer. Use that viewer to cut out just a small section of video. If anything is going wrong or not setup to suit you, you'll waste all that time doing it over. Convert a small section of video to see how it goes. MAke a .d2v of that cutout, then open it with an avs script in VirtualDub.
The DGIndex viewer has a slider and some buttons on the right. Click the "[" button to mark where you want your cut start. Then click the "]" button to mark where you want it to end. You'll notice when you move the slider that it sort of "jerks" several frames in motion -- that's because it's stopping on key frames. You want to start and stop on key frames.
Look over the DGIndex QUick Start guide referred to earlier. It's only one html page, will answer a lot of questions and get you started. Right now, you're doing it the hard way.Last edited by sanlyn; 21st Mar 2014 at 20:24.
nero crashed during burn
By mr-scarface in forum Authoring (DVD)Replies: 13Last Post: 14th Jan 2009, 22:41 -
Crashed and recovered
By Fluf in forum Newbie / General discussionsReplies: 21Last Post: 7th Jan 2009, 09:16 -
My PC Crashed and Don't know what codecs to get!
By faramith in forum Newbie / General discussionsReplies: 1Last Post: 1st Jan 2009, 10:39 -
Restoring information from crashed video file
By kocu in forum ComputerReplies: 5Last Post: 11th Dec 2008, 13:52 -
My Computer Crashed. I Can't Start It Up.
By moviebuff2 in forum ComputerReplies: 28Last Post: 29th Sep 2007, 11:34
