Is there any h264 frame accurate video editor I can use that will allow me to fast forward quickly?
Thanks Kerry - great suggestion.
I tried it again, and it's not bad. Better than solveigmm video splitter. But it's not as smooth as avidemux or tmpgenc authoring wizard. But those have their own issues... -
That doesn't solve the problem at all Kerry. Fast forwarding is still slow when you choose those options. The reason fast forwarding is slow is because the default h264 codec settings (nothing to do with any video program) use a default key-frame (IDR-Frame, in H.264) of 250. To get faster seeking you need to lower that number when encoding your video. 0 will make it as fast as MPEG2. The lower you go the larger the file sizes will get.
Testing H264/AVC frame accurate editing (AVCHD/MOV/MP4/MKV)) of SolveigMM
By DmitryV in forum EditingReplies: 18Last Post: 3rd Mar 2026, 15:15 -
Frame accurate cutting on m2ts files?
By stryker412 in forum EditingReplies: 3Last Post: 29th Jan 2012, 04:20 -
Frame accurate WMV edits
By jbeezer in forum EditingReplies: 5Last Post: 5th Jul 2010, 14:41 -
Suggest a video editor for frame-by-frame editing
By ontherocks in forum Newbie / General discussionsReplies: 14Last Post: 24th Apr 2008, 09:36 -
I'm looking for a good frame viewer
By SCDVD in forum Newbie / General discussionsReplies: 12Last Post: 6th Jul 2007, 01:02
