hi
for converting mpeg2 files into mkv files i used Avidemux. the original video file has been a TS file received by dreambox satellite receiver. i used VideoReDo to fix errors in it. i know no other tools to keep video and audio synchronous. the tool is very good for this purpose. the output of VideoReDo is the input file for Avidemux. the video encoder is x264.
when i use Avidemux for generating xvid output files, it generates frame exact. but in this case it produces output which is not cut at exactly the frame i choose to be the end of video. it includes some frames after the cut too.
then i use TMPGEnc Video Mastering Works 5 to cut the end of the produced video out. but this tool can't Copy video and seems that it has been designed for encoding. i also can't use this tool instead of Avidemux. it's not so easy. it also produces a very larger file. what can i do?
thx
Results 1 to 1 of 1
910115 - what's the best way to cut an mkv file?
By hamidi2 in forum EditingReplies: 12Last Post: 8th Apr 2012, 21:17 -
Avidemux and mkv
By pooksahib in forum EditingReplies: 2Last Post: 2nd Jun 2011, 00:50 -
chapters points missing from .MKV trimmed with AVIdemux
By DaveIsHere in forum Video ConversionReplies: 2Last Post: 22nd Aug 2010, 18:40 -
Avidemux MKV editing problem
By FatalX in forum EditingReplies: 6Last Post: 20th Sep 2009, 21:02 -
ogg in mkv with AVIDEMUX
By Kurgan71 in forum Video ConversionReplies: 4Last Post: 23rd Apr 2009, 04:51
