Actually, that's incorrect. From their product page, it specifically states "Make Blu-ray compatible AVCHD recordings, so you can burn your TV recordings onto a standard DVD disc (up to 2 hours of video at 5MBits/sec) and playback on Blu-ray disc players."
http://www.hauppauge.com/site/products/data_hdpvr.html
I guess the question now is whether the other, more recent releases are TRULY BD compliant. And I guess I should get busy re-encoding everything I've ever recorded
With regards to the appending and re-encoding, I re-encoded with TMPGENC, using the same settings as the original file. Then I used VRD to combine the files.
Results 61 to 77 of 77
I guess their definition of "blu-ray compatible" is very lax... Not to mention many BD players cannot even play "AVCHD" on DVD5/9 media . Some manufacturers even issue firmware on purpose to reduce compatibilty (you often have to find old firmware versions)
So vrd couldn't combine the files properly ? What does "absolutely nuts" mean exactly ? -
@digitalfreaknyc
I know you from originaltrilogy forums and I'm familiar with some of your releases
You were already making some BD25 discs before, were those actually AVCHD? I think there's no need to recode everything. Maybe BD players that can play Hauppauge files don't care if the your BD is spec complaint, maybe they ignore it and play it anyway. -
Thanks, man.
Yeah, everything I've been recording in HD has been from the Hauppauge. I've had it for years. However, this 3-frame-drop has driven me absolutely nuts. It's always there, whether it's noticeable or not. For me, being a perfectionist, it's always noticeable and it's like someone turning the knife every time I see it.
Up until now, I had no idea what the problem was. In speaking with people here and now on AVS forums as well, it turns out that the Hauppauge 1212 doesn't make 1080i files that are Blu-ray compliant, although they will play. Apparently the 720p files are totally fine but on the 1080i files, the encoder uses a GOP size above the blu-ray standard (the 1212 GOP size is 64, while the blu-ray maximum is 60). The biggest (and only problem, it seems) is this 3-frame-jump and the only way to get rid of it is to re-encode, as I'm being told, OR to not burn
I don't think any capture card with h.264 chip can produce Blu-Ray compliant files. There are settings for x264 that are Blu-Ray specific if you really want full compatibility.
Actually, for 1212 GOP size is 32 for non-IDR I frame (with additional IDR frame placed every 128 frames). I think for Blu-Ray GOP is shorter, something like 24 or 12 frames. Did you try to replace m2ts from TSMuxer with the one created with VRD? -
Chapters are placed in mpls playlists so I think not but I'm not sure.
As for Colossus 2, they use same chip as in HD-PVR 2 and I have HD-PVR 2 and I don't think they are compliant. Maybe they think compliant as AVCHD? -
See here:
http://www.avsforum.com/forum/26-home-theater-computers/1294938-hauppauge-colossus-hd-...l#post27646489
Been talking to that gent, who had the problem with the 1212 and no longer has it. I guess I should be going with that Colossus. -
It's possible to re-encode the first bit and append. But you have to do it properly . It's difficult for most people because you need to use command line programs. I posted how to do it in another thread if you want more details. The key is to use a different sps-id value for appended segments and to join binary segments (which had been split on IDR boundaries) . You can even use different encoding settings (it not necessary to match settings, because it's a different true GOP, not mini-GOP; but you do have to match rough bitrates for BD scenarios, because of the possiblity of buffer underflow). This works 100% of the time - I've never seen it fail. It works on yours as well
The spec allows 60 frame 2sec GOP, ONLY if specific requirements are met . For example ,the maxrate and buffer size have to be < 15000 , and L4.0 for the 2sec rule. Otherwise 1sec rules still apply, including 1 sec GOP .
@digitalfreaknyx - start reading about command line applications
. You always hear people complaining about various "glitches" between the append points at the "seams" , but that method works flawlessly everytime. It's been around for years (10 ?) ever since sps-id was introduced into x264 . Unfortunately it's quite involved and it seems nobody has made a GUI around it
Hey poisondeathray, I actually found out about sps-id thanks to you, I think
but that method is not flawless if you mix x264 part with some h.264 streams made by some hardware encoders even if you match most settings. I tried it few times and it's partially successful. Players kinda have problems around spliced part. For x264 joined with x264 (with different settings and version) everything works perfectly. I agree that it's a great trick to know when using x264 cli.
As for BD spec I think that for Colossus 2 those rules are respected. On their site they now claim 12 Mb/s for maximum avg. bitrate. In HD-PVR 2 it's 14 Mb/s. I doubt their buffer values violate the rules. -
Can you upload a sample that fails ? I've looked for one for a long time , HW encoders and different SW encoders included . In many respects , most HW encodes are "easier" because they conform to 1 set of rules, and usually fixed everything, GOP size, etc...
If you have something / a HW source that consistently fails, then it might be possible to identify why and code a fix -
ok thanks
The most common cause of "failure" is misidentified IDR boundaries. If you 've made sure you've cut correctly , it should work
For example, on digitalfreaknyx's sample, there are a few "i" frames which are likely candidates to cut on, but if you cut on those, it won't work.
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 17:25 -
convert .mkv from level @5.1 to level @4.1
By florinus in forum Newbie / General discussionsReplies: 4Last Post: 29th Nov 2010, 16:33 -
--b-pyramid
By catracho2009 in forum Authoring (Blu-ray)Replies: 7Last Post: 12th Jul 2010, 19:51 -
PS3 AVCHD, Ref Frame 8+Level 5.1+B-Pyramid...????
By NiGHTsC in forum Video ConversionReplies: 1Last Post: 29th Dec 2008, 19:45 -
Avi2DVD message when loading AVI...."DV DVI Detected"
By geek2330 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jun 2007, 08:05
