Been trying to find a way of simply playing and playing back protected video simultaneously on two displays - one is my third monitor on my desk and the other is a 40' LCD five feet behind me for the rest of the family. Tried powered HDMI Splitter, which worked, but caused a "jitter" in non-video apps and may have caused a couple of OS start lockups (still checking that out.) The Radeon 6790 operates all four displays perfectly except for........
Any ideas would be greatly appreciated.
I assume you want to play the same file on both the TV and the monitor, and only have one monitor and the TV on at the same time.
Have you tried using the TV as the primary monitor and the PC's monitor as the secondary monitor in clone desktop mode, with a DVI to HDMI cable connecting the monitor and a HDMI to HDMI cable connecting the TV? If the TV and the monitor are HDCP compliant, this setup seems like it should work, although I can't test it. Audio will only be provided by the TV (or your home theater system if HDMI is connected through it instead of directly to the TV) but that may be fine since the TV is nearby.
If this has been tried and does not work, does your family have an XBox 360 that could be used as a media extender? (The TV and monitor will still need to be HDCP compliant,)
Multi mkv files with subs into one disk to play to all bluray players
By fits79 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 27th Dec 2010, 06:27 -
WMP/WMC won't play Subtitled MKV's, MPC will?
By Rantlers in forum Blu-ray RippingReplies: 1Last Post: 28th Apr 2010, 05:54 -
Multi-monitor, multi-video feeds
By Robert Hedderman in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2010, 13:21 -
What WMC Extender offers the best playback?
By MikeMGMVE in forum Media Center PC / MediaCentersReplies: 1Last Post: 16th Oct 2008, 20:39 -
does IT convert protected audio files?
By doulos in forum ffmpegX general discussionReplies: 0Last Post: 13th Jul 2007, 04:41
