Hi,
I am thinking about buying a Plextor 16x CD writer... I plan on using Memorex High Capacity 16x cdrs... I have read some posts saying that high speed burning doesnt work... What I am wondering is, do any of you burn at around this high of speed? Do they produce ok VCDs and SVCDs? I have notived there is alot of confusion on this subject, so maybe someone can answer for all of us!
I've burned at 12x-it's as fast as I can burn and haven't noticed any change in quality. I only run into problems when I'm using cheap CDRs.
I too burn at 12x and have additional burn-proofing. I have never had problems with audio, mp3 or data burnt CD's when multi-tasking. However when burning VCD's, SVCD's and other video media types I have had to teach myself not to multi-task , as this sometimes interferes with the video stream. Why, I don't know, as the so-called burn-proof system is meant to eliminate this problem.
plextor makes only the best cd burners.
if you buy plextor, you won't have speed issues.
THIS IS HARDCORE -
make sure u buy compatible CD's
Higher cost CD's will work better as their dyes r better/ -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Not all high cost CD-R's are of good quality. You will often find that so-called branded CD-R's are actually made by the same companies who produce the no-name low cost CD-R's - they merely repackage them. If you look around the web you can find some interesting details on who makes what for whom, dye variances, quality tests etc. such as http://www.cdmediaworld.com/hardware/cdrom/cd_dye.shtml
<font size=-1>[ This Message was edited by: aldus4 on 2001-07-26 23:52:28 ]</font> -
i have a 16x also and i can burn vcd at 12x and svcd only at 4x or i get errors
I bought a Plextor 16x CDRW today!!!
I have burned 3 SVCDs at 16x, they work great!!! In under 6 minutes it burns a 1hour tv show!!!
High Speed Component Cables?
By dpunkz in forum Newbie / General discussionsReplies: 8Last Post: 21st Jun 2011, 22:27 -
JVC SR-DVM70US High Speed Dubbing
By sd1233 in forum DVD RippingReplies: 13Last Post: 29th Jul 2010, 14:58 -
High speed hdmi? Is this a marketing gimmick?
By yoda313 in forum DVB / IPTVReplies: 5Last Post: 1st Aug 2009, 21:01 -
DMR-EH50 High Speed Dubbing
By jjis in forum DVD & Blu-ray RecordersReplies: 1Last Post: 30th Jan 2008, 14:45 -
High-speed internet through wireless network? Help!
By Super Warrior in forum ComputerReplies: 7Last Post: 18th May 2007, 11:34
