Hi guys, I'm new here, so forgive my potential noobness. I'm right now looking into building a multipurpose HTPC, that can function as a media receiver and can be used to play PC games. Here en-lies the problem, I'm looking to build this computer to output 7.1 audio, as well as receive A/V input. The A/V inputs being RF, Composite, S-Video, VGA, Component, and HDCP Compliant HDMI. Also able to output in those same video ranges if need be too. So the problem with the build as it stands now is finding the right sound-card, and the right A/V input cards that have the low latency needed to use this PC as a theater receiver. Also what adapters can I use to convert Video outputs to the older Analog ones? This computer is going to be used for PC games, TV box DVR, Theater Receiver, and Media server.
Help please, I am at a dead end.
Everything you want is do-able except this "Input HDCP Compliant HDMI". AFAIK.
Why do you need to convert your output to older analog types?? as surely you will be outputting eithet to a PC monitor or a HDTV with HDMI?
list your inputs +sources and needed outputs and required storageCorned beef is now made to a higher standard than at any time in history.
The older outputs are for an older CRT HD 1080i TV I have that is for the old game consoles I have that have light-guns that need to read scan lines.
Media player verses htpc
By Marccc in forum Media Center PC / MediaCentersReplies: 2Last Post: 15th May 2010, 08:10 -
WDTV Live Media Player and the like vs. Desktop with HDMI port (HTPC?)
By edong in forum Media Center PC / MediaCentersReplies: 13Last Post: 19th Mar 2010, 13:30 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45 -
Media Center 2005 or Vista Premium for HD Video Editing/HTPC?
By emartin in forum ComputerReplies: 12Last Post: 22nd Jan 2008, 13:38 -
reciver hdd to pc?
By villi in forum Newbie / General discussionsReplies: 3Last Post: 25th Oct 2007, 09:32
