I backed up a DVD using DVD Decryptor. There are several .vob fles in the VIDEO_TS folder I wish to delete before burning this backup. However, after removing the unwanted .ifo, bup .vob files from the compilation (NERO), when I start the burn, NERO grouses and tells me the disk may be unplayable.
Presumably somewhere there is an index which is looking for these files. How do I fix this?
Summation:
Decrypt DVD with DVD Decryptor
remove unwanted .vob files (scenes I do not wish to burn)
remove .ifo and .bup files bearing same name as unwanted .vob files
Burn with NERO
Encounter errors which indicate NERO is looking for the deleted files.
Thanks for helping and Old Noob!
-- Doc
All the VOB files in a DVD fileset are linked in the index files (ifo). You can't just delete them and leave a playable DVD.
The indexes need to be rebuilt.
You could do this with DVDShrink, for instance which lets you choose exactly which elements to keep, as well as compressing the MPEG if you need that (say to fit a DVD9 to a DVD5).
You could also use VobBlanker or DVDStripper.Last edited by AlanHK; 2nd Apr 2012 at 18:34.
Removing 'soft-coded' subtitles for burning...
By twopups in forum SubtitleReplies: 11Last Post: 6th Apr 2012, 17:04 -
Burning VOBs - error "Couldn't find any VOB unit"
By kshavo in forum Authoring (DVD)Replies: 7Last Post: 17th Feb 2009, 13:23 -
Removing all info from dvd/vobs, but leave raw footage to edit?
By snek11 in forum Authoring (DVD)Replies: 2Last Post: 20th Jun 2008, 09:15 -
Splitting VOBs for burning to DVD ?
By paulwilko in forum Newbie / General discussionsReplies: 6Last Post: 5th Jun 2007, 03:37 -
Burning options for VOBs??
By Akhet in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2007, 17:32
