I have exported a video from the RAM minidisc of a Panasonic video camera. A previous file exported works fine on my PC but this one freezes for different bits of the video while the audio runs on continuously and becomes out of sync. I found an article on correcting this without losing the audio by using VDUB-MP3-FREEZE so I downloaded this and tried to use it. The file has the extension .mpg but when I tried to open it I got error 'MPEG Import Filter;pack synchronization error'. Further googling indicates that I need to know what sort of mpg file it is and what codec it needs.
The video is a recording of my 13yr old granddaughter playing the Haydn Trumpet Concerto witrh an orchestra so it is an unrepeatable event. The sound is good, the performance is good - I hope someone can suggest an approach I can take to restore the file.
first thing i'd do is take the disc out and clean it with a little dish soap and warm water, then dry with a cotton towel. then try to re-send the video. or finalize it in the cam and use the computer to read the disc and copy the files off it.
@aedipuss
Thanks for the reply, I have cleaned the disc as you suggested and I think it has effected some improvement. I have tried several bits of software to move on and now started a new thread in greater detail.
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 17:26 -
Panasonic HD Video Camera - .MTS file vs. MPEG-2 transport stream
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 24Last Post: 10th Aug 2010, 23:04 -
JVC GZ-HD6 camera mode very bad?
By steve_rb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 28th Dec 2009, 09:49 -
Bad tape or is my camera dying?
By Jeff_NJ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 9th Dec 2008, 00:24 -
Consumer video camera's that do 1 frame recording
By Jabroni4872 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 18th Aug 2008, 02:14
