Results 1 to 1 of 1
  1. Kentho
    Apr 2012
    Norway
    Nightmare trying to export avchd footage (shot with panasonic sd90) from adobe cs5.5 to Mpeg2-dvd format. The result on dvd is not good, a lot of shimmering lines and artifacts. When I use HD-writer AE 3 to export the m2ts-files to dvd, the result is exellent. I don't know what HD-writer does, but I can't get the same quality in adobe premiere export, and I have tried a lot of settings.
    Here's the original videofile data (m2ts-file):
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 97.8 MiB
    Duration : 32s 908ms
    Overall bit rate : 24.9 Mbps
    Maximum Overall bit rate : 28.0 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : High@L4.2
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Format settings, GOP : M=3, N=24
    Codec ID : 27
    Duration : 32s 600ms
    Bit rate mode : Variable
    Bit rate : 23.7 Mbps
    Maximum bit rate : 26.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 50.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.228
    Stream size : 92.0 MiB (94%)
    And here's the Mpeg2-dvd export from premiere
    (cut/part of the original footage):
    Format : MPEG-PS
    File size : 11.3 MiB
    Duration : 10s 259ms
    Overall bit rate : 9 272 Kbps
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Format settings, GOP : M=3, N=15
    Duration : 10s 240ms
    Bit rate : 7 552 Kbps
    Maximum bit rate : 8 000 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.728
    Stream size : 9.22 MiB (81%)
    You can view the videoresult here:
    http://www.youtube.com/watch?v=VrtksUzzGLo&feature=youtu.be
    I know it's progressive footage I've converted to interlaced, because I want the motion to be smooth. But I have also tried original interlaced footage with the same result. And I tried progressive footage and exported it progressive, and even if the result was slighly better, it's far from good, like the impressive export from HD-writer. I observed that HD-writer had coverted the progressive footage to interlaced, upper field with great sucess.
    I can't stop thinking that it must be possible to achieve the same result with adobe export as with the HD-writer software. I would use hd-writer, but it's very limited on the editing side, and it will only accept the native camera file-format to export to dvd. I want to edit in premiere, and get a good quality export without the shimmering lines. I have checked the maximum rendering quality, and maximum bit depth without any luck.
    Anyone have an idea what to do? I'm really stuck.
