Page 4 of 4
FirstFirst ... 2 3 4
Results 91 to 116 of 116
  1. Member 2Bdecided's Avatar
    Nov 2007
    Originally Posted by themaster1 View Post
    that's better now
    Old cap Vs New cap:
    http://imageupload.org/en/file/210586/oldvsnew.jpg.html
    ...but now the blacks are clipped out! And many of the other samples later in this thread still show horrible clipping of whites.
    I suspect the levels are all over the place with this tape. Find a proc amp setting that lets you capture all the tape without any clipping, and then use something like HDRAGC in AVIsynth to do a nice automatic fix (if you can't fix it manually).
    Cheers,
    David.
  2. You're gonna laugh (or not probably) but i can't find the right settings again
    what i did
    MPEG2Source("Untitled.d2v", cpu=0,info=3)
    # Deblocking interlaced source
    par=getparity()
    SeparateFields().PointResize(width,height)
    Deblock_QED(24,28,uv=3)
    AssumeFrameBased()
    SeparateFields()
    Merge(SelectEven(),SelectOdd())
    par ? AssumeTFF() : AssumeBFF()
    Weave()
    # color yuv (to work with msu old color)
    coloryuv(gain_u=-60, gain_v=60)#
    SmoothLevels(0, 0.75, 255, 16, 235, Limiter=0)
    The idea was to make it work with msu old color so i have gave these crazy-60/+60 values like on the picture on the msu webpage or close
    msu old color (1,0,auto levels yes,accuracy 2)
    Then, msu color enhancement (hdr yes,4,2)
    Then color mill( that's where things are getting blurier)
    and to finish get rid off the ugly blue/cyan with HSI (hue,sat,intensity) (saturation= -43)
  3. Well you're lucky i've managed to find the right settings or very close
    Download this and read the txt file:
    https://forum.videohelp.com/attachment.php?attachmentid=11809&stc=1&d=1333632175
    Dec 2011
    Denmark
    Great ill test it and get back to you
    Dec 2011
    Denmark
    Master what about the avs script allready on it ???
    DirectShowSource("C:\Users\Admin\Documents\elmebak ken.mpg")
    ConvertToYV12(interlaced =true)
    AssumeTFF()
    SeparateFields()
    a=last
    clense(reduceflicker=false).merge(last,0.5).clense (reduceflicker=false)
    mot=removegrain(11,0).removegrain(20,0).DepanEstim ate(range=2)
    take2=a.depaninterleave(mot,prev=2,next=2,subpixel =2)
    clean1=take2.TMedian2().selectevery(5,2)
    sup1 = clean1.minblur(1).removegrain(11,0).removegrain(11 ,0)
    \ .mt_lutxy(clean1,"x 1 + y < x 2 + x 1 - y > x 2 - y ? ?",U=2,V=2)
    \ .msuper(pel=2,sharp=0)
    sup2 = a.msuper(pel=2,levels=1,sharp=2)
    bv22=sup1.manalyse(isb=true, truemotion=false,global=true,delta=2,blksize=16,ov erlap=8,search=5,searchparam=4,DCT=5)
    bv21=sup1.manalyse(isb=true, truemotion=false,global=true,delta=1,blksize=16,ov erlap=8,search=5,searchparam=4,DCT=5)
    fv21=sup1.manalyse(isb=false,truemotion=false,glob al=true,delta=1,blksize=16,overlap=8,search=5,sear chparam=4,DCT=5)
    fv22=sup1.manalyse(isb=false,truemotion=false,glob al=true,delta=2,blksize=16,overlap=8,search=5,sear chparam=4,DCT=5)
    interleave(a.mcompensate(sup2,fv22),a.mcompensate( sup2,fv21),a,a.mcompensate(sup2,bv21),a.mcompensat e(sup2,bv22))
    sup3 = last.msuper(pel=2,sharp=2)
    bv33=sup3.manalyse(isb=true, truemotion=false,global=true,delta=3,blksize=8,ove rlap=4,search=5,searchparam=4,DCT=5)
    bv32=sup3.manalyse(isb=true, truemotion=false,global=true,delta=2,blksize=8,ove rlap=4,search=5,searchparam=4,DCT=5)
    bv31=sup3.manalyse(isb=true, truemotion=false,global=true,delta=1,blksize=8,ove rlap=4,search=5,searchparam=4,DCT=5)
    fv31=sup3.manalyse(isb=false,truemotion=false,glob al=true,delta=1,blksize=8,overlap=4,search=5,searc hparam=4,DCT=5)
    fv32=sup3.manalyse(isb=false,truemotion=false,glob al=true,delta=2,blksize=8,overlap=4,search=5,searc hparam=4,DCT=5)
    fv33=sup3.manalyse(isb=false,truemotion=false,glob al=true,delta=3,blksize=8,overlap=4,search=5,searc hparam=4,DCT=5)
    last.mdegrain3(sup3,bv31,fv31,bv32,fv32,bv33,fv33, thSAD=499)
    Interleave()
    Weave()
    #####interpolate bad frames and residual cleaning
    Super = msuper()
    bv1 = manalyse(Super, isb=true, delta=2)
    fv1 = manalyse(Super, isb=false, delta=2)
    bv2 = manalyse(Super, isb=true, delta=3)
    fv2 = manalyse(Super, isb=false, delta=3)
    global CandidatesForN = mflowinter(Super, bv2, fv2, time=33.3, ml=100)
    global CandidatesForO = mflowinter(Super, bv2, fv2, time=66.7, ml=100)
    global CandidatesForC = mflowinter(Super, bv1, fv1, time=50.0, ml=100)
    last
    rx(104,12) #104-116 replaced
    AssumeTFF()
    SeparateFields()
    f1=SelectEven().RemoveDirtMC(100,false).LSFMod(str ength=5)
    f2=SelectOdd().RemoveDirtMC(100,false).LSFMod(stre ngth=5)
    Interleave(f1,f2)
    Weave()
    function MinBlur(clip clp, int r, int "uv")
    uv = default(uv,3)
    uv2 = (uv==2) ? 1 : uv
    rg4 = (uv==3) ? 4 : -1
    rg11 = (uv==3) ? 11 : -1
    rg20 = (uv==3) ? 20 : -1
    medf = (uv==3) ? 1 : -200
    RG11D = (r==0) ? mt_makediff(clp,clp.sbr(),U=uv2,V=uv2)
    \ : (r==1) ? mt_makediff(clp,clp.removegrain(11,rg11),U=uv2,V=u v2)
    \ : (r==2) ? mt_makediff(clp,clp.removegrain(11,rg11).removegra in(20,rg20),U=uv2,V=uv2)
    \ : mt_makediff(clp,clp.removegrain(11,rg11).removegra in(20,rg20).removegrain(20,rg20),U=uv2,V=uv2)
    RG4D = (r<=1) ? mt_makediff(clp,clp.removegrain(4,rg4),U=uv2,V=uv2 )
    \ : (r==2) ? mt_makediff(clp,clp.medianblur(2,2*medf,2*medf),U= uv2,V=uv2)
    \ : mt_makediff(clp,clp.medianblur(3,3*medf,3*medf),U= uv2,V=uv2)
    DD = mt_lutxy(RG11D,RG4D,"x 128 - y 128 - * 0 < 128 x 128 - abs y 128 - abs < x y ? ?",U=uv2,V=uv2)
    clp.mt_makediff(DD,U=uv,V=uv)
    return(last)
    # median of 5 clips from Helpers.avs by G-force
    Function Median2(clip "input_1", clip "input_2", clip "input_3", clip "input_4", clip "input_5", string "chroma")
    chroma = default(chroma,"process") #default is "process". Alternates: "copy first" or "copy second"
    #MEDIAN(i1,i3,i5)
    Interleave(input_1,input_3,input_5)
    chroma == "process" ? Clense(reduceflicker=false) : Clense(reduceflicker=false,grey=true)
    m1 = selectevery(3,1)
    #MAX(MIN(i1,i3,i5),i2)
    m2 = input_1.MT_Logic(input_3,"min",chroma=chroma).MT_L ogic(input_5,"min",chroma=chroma).MT_Logic(input_2 ,"max",chroma=chroma)
    #MIN(MAX(i1,i3,i5),i4)
    m3 = input_1.MT_Logic(input_3,"max",chroma=chroma).MT_L ogic(input_5,"max",chroma=chroma).MT_Logic(input_4 ,"min",chroma=chroma)
    Interleave(m1,m2,m3)
    selectevery(3,1)
    chroma == "copy first" ? last.MergeChroma(input_1) : chroma == "copy second" ? last.MergeChroma(input_2) : last
    Return(last)
    function TMedian2(clip c) {
    Median2( c.selectevery(1,-2), c.selectevery(1,-1), c, c.selectevery(1,1), c.selectevery(1,2) ) }
    function RemoveDirt(clip input, int limit, bool _grey)
    clensed=input.Clense(grey=_grey, cache=4)
    alt=input.RemoveGrain(2)
    return RestoreMotionBlocks(clensed,input,alternative=alt, pthreshold=6,cthreshold=8, gmthreshold=40,dist=3, dmode=2,debug=false,noise=limit,noisy=4, grey=_grey)
    # Alternative settings
    # return RestoreMotionBlocks(clensed,input,alternative=alt, pthreshold=4,cthreshold=6, gmthreshold=40,dist=1,dmode=2,debug=false,noise=li mit,noisy=12,grey=_grey,show=true)
    # return RestoreMotionBlocks(clensed,input,alternative=alt, pthreshold=6,cthreshold=8, gmthreshold=40,dist=3,tolerance= 12,dmode=2,debug=false,noise=limit,noisy=12,grey=_ grey,show=false)
    function RemoveDirtMC(clip,int limit, bool "_grey")
    _grey=default(_grey, false)
    limit = default(limit,6)
    i=MSuper(clip,pel=2)
    bvec = MAnalyse(i,isb=false, blksize=8, delta=1, truemotion=true)
    fvec = MAnalyse(i,isb=true, blksize=8, delta=1, truemotion=true)
    backw = MFlow(clip,i,bvec)
    forw = MFlow(clip,i,fvec)
    clp=interleave(backw,clip,forw)
    clp=clp.RemoveDirt(limit,_grey)
    clp=clp.SelectEvery(3,1)
    return clp
    function R(clip Source, int N)
    # N is number of the frame in Source that needs replacing.
    # Frame N will be replaced.
    Source.trim(0,-N) ++ CandidatesForC.trim(N-1,-1) ++ Source.trim(N+1,0)
    function RP(clip Source, int N)
    # N is number of the first frame in Source that needs replacing.
    # Frames N and N+1(O) will be replaced.
    Source.trim(0,-N) ++ CandidatesForN.trim(N-1,-1) \
    ++ CandidatesForO.trim(N-1,-1) ++ Source.trim(N+2,0)
    function RX(clip Source, int N, int X)
    # N is number of the 1st frame in Source that needs replacing.
    # X is total number of frames to replace
    #e.g. RX(101, 5) would replace 101,102,103,104,105 , by using 100 and 106 as reference points for mflowfps interpolation
    start=Source.trim(N-1,-1) #one good frame before, used for interpolation reference point
    end=Source.trim(N+X,-1) #one good frame after, used for interpolation reference point
    start+end
    AssumeFPS(1) #temporarily FPS=1 to use mflowfps
    super = MSuper()
    backward_vec = MAnalyse(super, isb = true)
    forward_vec = MAnalyse(super, isb = false)
    MFlowFps(super, backward_vec, forward_vec, blend=false, num=X+1, den=1) #num=X+1
    AssumeFPS(FrameRate(Source)) #return back to normal source framerate for joining
    Trim(1, framecount-1) #trim ends, leaving replacement frames
    Source.trim(0,-N) ++ last ++ Source.trim(N+X+1,0)
    ColorYUV(gain_y=-12,gain_v=-5,gain_u=+10)
    SMoothTweak(saturation=0.8)
    Dec 2011
    Denmark
    Should i still use that and if so where do i put the avs script you wrote?
  7. Dear asesinato he put you just example don't stack it with the previous one you will also need dll from here http://avisynth.org/mediawiki/DeBlock.
    I don't know what the script should do but you deffenetly need noise reduction also badly on that source.
    Don't you have the tapes any more? I admire masters dedication when it's more simple and better to recapture with correct setting and losless
    why are you not doing that already?
    cheers mammo1789
    Dec 2011
    Denmark
    Trust me the tape looks the same, just as bad as this copy... There is nothing to gain by recaping
  9. No first thing first you must use the small script i gave you in the zip ,the which you open in vdub, load the .vcf, check the msu values and save in avi lossless (lagarith, yv12)
    Only then you will use that slow-large-defecstKiller script and save again in avi lossless to remove noise (with vdub again,fast recompress mode)
    This large script contain a part to rebuild severely damaged frames (rx) so you will have to pick them manually
    ex:
    Super = msuper()
    last
    rx(6000,1) # frame 6000 is replaced
    rx(104,12)
    #frames 104 to 116 are replaced
    AssumeTFF()
    SeparateFields()
    f1=SelectEven().RemoveDirtMC(500,false).LSFMod(str ength=50)
    f2=SelectOdd().RemoveDirtMC(500,false).LSFMod(stre ngth=50)
    Interleave(f1,f2)
    Weave()
    Note: it's preferable you don't use it on consecutive damaged frames otherwise -> problems
  10. Trust me the tape looks the same, just as bad as this copy... There is nothing to gain by recaping
    I trust you the tape is crap, but i cant trust you that you cant gain with recapturing ( because you obviously are not reading all the earlier posts) because is not true.
    Listen what master is saying ( and all others for that mater ) to you and take step at a time not just trough everything on it it just don't work that way.
    Patience my friend
    Dec 2011
    Denmark
    That deblock_qed i can only find a .avs file called that when i search google? do you have a link?
  12. Dear asesinato he put you just example don't stack it with the previous one you will also need dll from here http://avisynth.org/mediawiki/DeBlock.
    right corner of the page where is says abstract download
    you put deblock_qed.avs script in plugins folder of avysinth
    Dec 2011
    Denmark
    Yeah mate but that dont work.... Its not what he uses in the script???
    Its says there is not such function when even if i have put the files in deblock12.zip (45.6 KB, 0 views) in the plugins dir at avisynth
  14. you put deblock_qed.avs script in plugins folder of avysinth the deblock12.zip( the deblock dll is needed for the avs to work)
  15. I think that my friend master confused you totally
    you need the plugin and also the avs in the plugins folder so to master script can work
    Dec 2011
    Denmark
    Still dont work...
    no such function named Deblock_QED
    I have the deblock12.zip unzipped in plagins dir and deblock_qed.avs lays in there to... What im i doing wrong ?
  17. Import deblock_qed.avs into the script you're using. Or put deblock_qed.avs in your AviSynth plugins folder and rename it deblock_qed.avsi so it's automatically imported every time you use Avisynth.
  18. this one do you have it in the folder if not put only dll file
  19. Import deblock_qed.avs into the script you're using. Or put deblock_qed.avs in your AviSynth plugins folder and rename it deblock_qed.avsi so it's automatically imported every time you use Avisynth.
    jagabo run me first exactly that
  20. ConvertToYV12 you will also need it in the master script
    Dec 2011
    Denmark
    new error
    end of file reached with a matching }
    MPEG2Source("Composite_20120402_1817.d2v", cpu=0,info=3)
    par=getparity()
    AssumeFrameBased()
    SeparateFields()
    Weave()
    coloryuv(gain_u=-60, gain_v=60,autowhite=false,showYUV=false)#
  22. MPEG2Source("here put you file example c:\badvideo.d2v", cpu=0, info=3)
    par=getparity()
    AssumeFrameBased()
    SeparateFields()
    Weave()
    without the "here put you file example" i guess you figure it out the mpeg2source should point to place where your file is located on the hdd
  23. It's more crap then before i think that we are not getting any where here
    I think that my version is much better although still crap
  24. *** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
  25. Member
    Dec 2011
    Denmark
    Still same error : end of file reached with a matching }
  26. Member
    Dec 2011
    Denmark
    Error found and fixed
