I had a mp4 video file recorded by my mobile phone, when I moved it to my PC it was corrupted and I attempted to play it various time but it didn't, when I tried to play it with VLC player I get this error:
No suitable decoder module:
VLC does not support the audio or video format "undf". Unfortunately there is no way for you to fix this.
Here is the text from mediainfo:
If someone can help I'll appreciate it, thanks.General
CompleteName : G:\\201104789654.mp4
Format : MPEG-4
Format_Profile : Base Media / Version 2
CodecID : mp42
FileSize/String : 6.51 MiB
You could try "remux" it with mymp4boxgui or yamb. Add the mp4 and then make a new one.
If it fails I'm not sure what you can use. -
are you sure it is corrupted? Assuming it does not contain any sensitive data you could upload it somewhere (or attach it here) so people can have a look at it,... other than that:
compare a working with a corrupted file with a hex editor and see if you can figure out what went wrong,..
(http://mp4cam2avi.sourceforge.net/ might also be worth a try) -
"undf" sounds like VLC-speak for "I don't know what this is". Try MPC-HC to see if it can play the video.
If you don't particularly need MP4, try using MKVMergeGUI to resave the file as an MKV. It should report any problems it finds in the process. -
Have you tried uploading the video to YouTube and then downloading it from your video manager, I tried loads of other solutions and that's the only one that worked when I got a corrupt MP4 from a client. You lose a bit of quality but if you're stuck it may save you.
FLV file repair needed
By carriepr in forum Video ConversionReplies: 31Last Post: 17th Oct 2012, 01:50 -
Repair Recovered .mp4 file
By Khalid-S in forum Newbie / General discussionsReplies: 17Last Post: 25th Aug 2012, 05:24 -
How to repair a corrupt MP4 file (for free)?
By KeyMs92 in forum Video ConversionReplies: 1Last Post: 1st Aug 2011, 11:43 -
Repair of MP4 file
By Anodyne in forum RestorationReplies: 16Last Post: 5th May 2011, 02:28 -
need to repair mp4(and jpeg) file..
By glen_s in forum Newbie / General discussionsReplies: 1Last Post: 25th Sep 2007, 12:09
