I tried to convert a bluray disc to .avi 720p and I face video bitrate issues. On two-pass mode, I selected average video bitrate 3800 kbps in 1280X720 resolution but the output ended to be roughly at 3100 kbps video bitrate.
I tried 2 times with Megui (via File Indexer) and 2 times with Virtualdubmod (via Directshowsource). Both converters gave approximately the same results (regarding video bitrate).
Could someone enlighten me to do sth in order to achieve bigger video bitrate? Should I experiment with the max and min quantizers (I used h.263, I don't want to use a custom quantizer)??? Or sth else???
assuming you use Xvid for compression:
1. adjust Overflow Treatment Settings (i.e. all to 10 or 15)
2. set min Quantizer to 1
Salt bluray to mp4/avi issue
By BIFFtheSTIFF in forum MacReplies: 3Last Post: 16th Jun 2011, 13:28 -
Issue with captured video: 673GB AVI = 4.19 sec??
By photodyer in forum Capturing and VCRReplies: 6Last Post: 27th Jan 2011, 04:06 -
H.264 Bluray m2s bitrate question
By schmickers in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 6th Dec 2010, 14:57 -
TMPGEnc "clip total bitrate too high for a DVD-Video" issue
By dread in forum Authoring (DVD)Replies: 7Last Post: 26th Oct 2010, 16:34 -
Need Guide for Bluray Disc Ripping and to Make AVI (Xvid) from Bluray After
By dabas in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2010, 15:05
