I have some clips in After Effects CS3 with contain many 1000's of strokes/brushes created with the "Paint" tool.
All are the same colour. Only the opacity and shape varies.
Is it possible to similtaneously change the colour of a selected group existing brushes/strokes? Say 300 or 600 or 1000 at a time?
I only know how to change each stroke individually, which would take forever.![]()
One way to do it is to copy the effect to an adjustment layer (disable the effect for the original layer) and change the color that way (apply some color effect to the adjustment layer)
To select specific strokes instead of them all on the paint layer, you would need to crtl-select each stroke (with the layer expanded) before copying to the adjustment layer -
Thanks - I'm now halfway there!
I copied Paint strokes to an Adjustment Layer above, and disabled the Paint FX on my main layer of video footage.
Trouble is, when I apply an effect (ie. hue and saturation) to the adjustment layer, changes also affect all of the video below, not just the Paint strokes in my adjustment layer.
How do I isolate the color changes I make?
Here's a screenshot of my workspace at the moment (all brushes have been copied over, I'm just not showing them):
Duplicate the layer (assuming you want all the strokes affected), on the top layer toggle the Paint on Transparent to "on", then apply your color effect
Brilliant.
Thanks PDR. Still here, still sharing your awesome knowledge.
Does changing file extension from .f4v to .flv have any negative effects?
By huntaaar in forum Video ConversionReplies: 5Last Post: 2nd Sep 2010, 12:49 -
Changing Photoshop background colour
By Rudyard in forum ComputerReplies: 4Last Post: 15th Jun 2009, 23:50 -
Changing Night Mode Cam Video to Normal Colour or B/W
By Mr Baldman in forum RestorationReplies: 2Last Post: 3rd Jan 2009, 05:06 -
changing bitrate on existing wmv
By Stevenroy in forum Newbie / General discussionsReplies: 1Last Post: 17th Oct 2008, 20:04 -
Deep Colour/xvYCC colour/x.v.colour confused consumer
By ArthurDaley in forum DVB / IPTVReplies: 10Last Post: 9th May 2007, 19:10
