  1. I just ran into a Divx 5.0 movie and was trying to convert it to SVCD. I ran Virtual Dub 1.3c the file opens but its just a blank screen. I get the same results using Tmpgenc. I know this is a pretty new format and wasnt sure if its possiable yet. I have the 5.0 codec installed and I can open the file with there player. Thanks for any help
  2. Try loading the Divx 3 and 4 codecs and see if you get a picture in Tmpgenc.
    That fixed my problem.
    Talanx
  3. Thanks Talanx that did it I had to reinstall Divx 4.12
