I discovered an ancient video in vcd format which is still relevant today and would like to extract it a format for archiving an use. Which format is best for this?
i understand that the actual video is in the mpgav folder and has an extension of dat which is actually a mpg 1videl file with error correction
I have also found that the original size of the video is quite small so how come it was supposed to show full screen on a TV in those good ol days?
Can you brief me on lossles (minimum loss) resizing as i would require the video upsized too
I agree, for archiving I would not reencode, but instead of isobuster I would use vcdgear.
- old crt TV resolution was 640x480, so 352x240 was like watching 960x540 on your FullHD DisplayI have also found that the original size of the video is quite small so how come it was supposed to show full screen on a TV in those good ol days?
- old crt TV always has some sort of 'afterglow' (not sure what the right term is) due to the way they work, which also blurs the whole thing a bit
If you have the time you can read up about Avisynth and filtering to resize&filter your content and later save it to h.264 + aac lc inside a mp4 container. (Hybrid + avisynth extensions, and other tools like StaxRip, MeGui, RipBot, also offer some basic to advanced Filtering through Avisynth, so it might be worth checking these tools,... + all current NLE tools should come with some basic filtering support)Can you brief me on lossles (minimum loss) resizing as i would require the video upsized too
http://forum.doom9.org/showthread.php?t=154141 might be an interesting read,..
Cu Selur
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 13:23 -
Lagarith vs HuffYUV, archiving and file size
By HDClown in forum Capturing and VCRReplies: 62Last Post: 30th Jul 2012, 08:08 -
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 11:25 -
Help Regarding convert the large size videos of several format
By darkstonecold in forum Video ConversionReplies: 18Last Post: 3rd Sep 2009, 15:27 -
Empty file when converting vcd (.dat) format to ipod (mpeg4)
By happyriceman in forum ffmpegX general discussionReplies: 3Last Post: 5th Jul 2008, 06:19
