I have quite a few MKV files that I would like to convert over to MP4 containers. Virtually all are h264/AC3 so I want to simply swap containers. However, I'd also like to preserve subtitles when possible. I want the flexibility to NOT re-encode the video and/or audio. Questions are,
1. Any suggestions on freeware tools to do this, with batch conversion capability?
2. In lieu of this, any suggestions on a reliable paid application to do so?
Subtitle support is important. I've been trying xmedia recode, however it appears unable to preserve subtitles in MKV during the conversion to MP4; it strips them out.
Results 1 to 10 of 10
Perhaps the tool in this thread?
https://forum.videohelp.com/threads/340675-Mkv%D0%A2%D0%BEMp4-v0-219-rapid-tool-for-repack-Mkv-to-Mp4 -
Also check out winff. It will remux the file for you. Though I don't know what subtitle support it has. I would assume it would keep it intact. You can try it out (freeware) and see if it meets your needs.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
The general problem with subtitles inside mp4 is ttxt (mp4's own subtitle format), it is rather restricted and most (hardware) players do not even support all the options it provides, so you basically end up with plain text subtitles without all the styling. (this can be problematic if i.e. ass was used in an extensive way)
Hybrid (+ BDSup2Sub if ocr is needed) can to mkv -> mp4 conversions with basic subtitle handling, but depending on your input it might be a good idea to do some stuff manually.
Cu Selur -
Seems to me handbrake should be able to do this.
If you output to an mp4 container in handbrake it will embed subs in the file, but it will default to an m4v file (if I remember the name right ... I use mkvs with embedded subs). That's because only quicktime supports an mp4 container with subs.
You'll need a player with quicktime support like smplayer to get that feature. The file can be renamed to mp4 but without quicktime support in the player you won't get the subs.
I'm curious, though ... what's wrong with the mkv container? It's pretty well supported nowadays. -
Nope,.. Quicktime is definitely not the only player that supports subtitles in mp4 Files. And Players that do so do not need quicktime support, just a decent splitter and a subtitle renderer that supports mp4 subtitles,... (same as with subtitles inside an mkv file,..)That's because only quicktime supports an mp4 container with subs.
Plz pardon the necro, but I'm researching via Google how to do precisely what the OP has asked and came across this reply.
Yes, MKV is reasonably well supported - by everything except Windows itself (Win 7, anyway). I can't tell you how many ways I've tried to get Windows to display the properties of an MKV in (file) Explorer. Yes, I can obtain this via MediaInfo, but this done a single file at a time.
What I want is to be able to have a folder full of MPG, AVI, WMV, MP4 and MKV files and sort them in Explorer by run time, frame width, frame rate... or any other appropriate characteristic.
THIS is the reason I wish to change the container from MKV to MP4 without having to recode it. -
i try to convert
HD 720p @ 60fps / 4500 Kbps / H264 / AAC / 1280x720
to mp4
but i get out of sync video and audio ++ when i try to play .. few secconds video delays before play -
sounds a bit like the time codes weren't copied,...
What tool(s) for MP4 to MKV conversion with no reencoding?
By zdvd in forum Video ConversionReplies: 35Last Post: 17th Dec 2016, 07:38 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Conversion from MKV to AVI/MP4 Artifacting
By SakuyaFM in forum Video ConversionReplies: 4Last Post: 14th Sep 2010, 20:41 -
MKV (h.264 file) conversion to AVI or MP4
By killwill169 in forum MacReplies: 43Last Post: 12th Aug 2009, 18:35 -
AppleTV - Conversion of MKV to HD MP4
By Austehn in forum Video ConversionReplies: 7Last Post: 22nd Oct 2008, 19:28
